Battery drain
Hi, drivers side window is starting to act up, as in when you lower window it goes 1/2 way down then tries to come back up. Any ideas why?
  • Replies 51
  • Views 11.3k
  • In a mk1 Fabia the gateway is a submodule on the same circuit board as the onboard supply control unit (often referred to as BCM). As such it can't be swapped out other than by replacing the whole mod
  • ordered a new drivers door switch pack, windows now working again!!
