Hmmmmmmmm
I've just finished putting the car back together after putting central locking in my Fabia.
I've got a small black screw left - does anyone know where it goes?:)
Its the one that put in that is not needed,
if in the future your doors fall off when doing 70 down the motor way, I may be wrong and it could be that screw!!!:rofl:
Hope this helps,
Chris:)
Its the one that always cross threads and then falls out, so you've saved yourself a bit of time, well done!
In all fairness you have done very well to limit it to ONE spare I always end up with at least 4 spare parts!!!!:D
i always thought that wa the point of stripping and rebuilding things to see how many bits you have left. ;o)
I took my HU out the other day, and fangled about with taking some other parts off, and then put it all back together and ended up with 1 screw over, im sure i only took 3 off :/
you will hopefully see an increase in performance. the power to weight ratio is looking good now!
The only black screw I know of in the doors is the one that goes behind the tweeter and secures the door handle to the door. It should be a T25 torx.
