Side light upgrade require coding ??
Hey guys,
I want to upgrade the yellow bulb that illuminates the side light stripes in the headlight to something xenon like. Has anyone done this and does it require coding like the number plate led's?
I have a bulb kit incoming so everything yellow will not be soon.
If you replace with an equivalent rating incandescent bulb with a higher K rating (i.e. whiter) then no coding change is needed, but if you change to an LED then coding will be needed.
Thanks for the heads up. Any idea what coding is required. I found the led nunber plate coding post. But haven't come across one for the side light
Not so much coding as changing the value in the adaptation channel relevant to the sidelights  that specifies the bulb type: Leuchtenxxx xxn-Lasttyp
Thanks much appreciated
https://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/page/2/#comment-4431164
Coding for LED sidelight bulbs on Xenon headlights
Controller 09
Security Access 31347
Adaptations
The channels you need to change are:
(1)-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 to 6 - LED Lichtmodul
(1)-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 to 6 - LED Lichtmodul
Controller 09
Adaptations
Your a star thank you @BATVANVRS
