Stronger gas strut for boot
After I've isolated the boot it's a bit heavier.
Checked the part number for the gas strut and it it with 530N of force.
I've ordered 2 new one with 690N of opening force. The rest of the specs are the same. for lengths, diameter, etc..
Should it be any issues in fitting them?
Edited by ccosmin
I think it's fairly straightforward just be gentle with the clips as they can break.
Got a link for the uprated ones? Mine a mega weak.
Isn't obvious which ones have 690N force
I'll keep digging.
Sorry, that was the original part. This the the one for 690: AUDI, VAG (4B9827552M). There are several ones. I picked the one with 500mm length and 200mm stroke.
Hi,
My new gas struts arrived over the weekend and it seems they are a bit 2 strong.
Apparently only 1 new does the job, so now I have left: 530N and right: 590N of power;
Does anyone see any problems here? should I have them synced with 2 600N ones, or it's ok to have them different?
Thinking about issues on the different force applied just 2 one side....
There might be a bit more torsion between sides but I doubt that will be that noticeable short term. Summer temps could be interesting! The spring rate increases as it gets hotter. Even standard struts have caught me out a few times underestimating how much force needed to close the door some sunny days. There’s a lot less force needed to close on a cold day, though.
Matched pair of 560 ish?
I would go for a pair of matching force, but if there is no issue having them like this, I would not hurry in searching, buying.. laborious work :)
