Flashing coil light fault
Hi all, just for info I had a flashing coil light with limp mode a couple of days ago, code read P0238. Garage changed the Boost Pressure Sensor and test drove it.
Collected the car and within 1/2 mile dash light lit up, took the car back and after further investigation found a broken wire in the associated loom down in the depths. Soldered the wire and fixed the problem.
Pete.
