Digital speedo display disappeared
I have an 18 plate Fabia 7speed auto courtesy car. I has not come with a manual or any information. I am v happy with the car except that today I somehow lost the digital speedo display. No amount of button pushing will restore it. I have tried rotating the right hand knurled wheel on the steering wheel as suggested elsewhere on the site but it is of no help.
Also, the odometer reset button below the screen is not split as I have seen on some models so I can’t use that!
Advice welcomed please.
Right hand side of steering wheel there’s a button that looks like two overlapping boxes. When you press that use the right hand scroll wheel to navigate onto ‘vehicle information’ or similar and press the scroll button in to select it.
Thereafter you might see something like consumption, average consumption, oil temp etc. Then use the right hand scroll wheel (no need to press it in this time) and you should be able to find it again.
Hope this helps!
Brilliant, it worked!
Many thanks.
I tried the button previously but had’t found the correct option. 😁
HTH
Thanks AG Falco
