extra VAG-COM settings for Fabia
Here are some more Fabia ECU settings that can be programmed with VAG-COM. they come from OpenObd.org (Babelfish translated from German, but some parts really quite unclear).
I have used some of the coding - changed country code, adjusted the highway flashers and the default wipers. However, my usual disclaimer applies.
Cheers:thumbup:
Bas
{electrical system}
STG 09 (electrical system) select
STG coding - > function 07
Coding number (basis): 000000
+00016 - 4-tuerige execution
+00128 - heatable outside mirrors
+01024 - Tail cover remote unlocking remote operated
+08192 - Rear windshield wiper with comfort circuit
+16384 - Control electrical washer pump
Controller adjustment
STG Login - > function 11 Note: Before the adjustment a Login has to take place.
Login code: 21343
STG adjustment - > function 10
- > channel 001 (clamp 30G)
30G clamping wedges – withdrawal??????
Range of values: 1-253 = 0,66-173 min/
Default value: 44 = 30 min
- > channel 002 (heated windshield)
Disconnection time of the heated windshield.
Default value: 29 = 20 min
- > channel 003 (heated outside mirror)
Disconnection time of the heated outside mirrors.
Default value (to 04/02): 29 = 20 min
Default value (starting from 05/02): 254 (without disconnection)
- > channel 004 (heated back window)
Disconnection time of the heated back window.
- > channel 005 (boot remote unlocking)
Time of the remote button press for boot remote unlocking.
Range of values: 1-254 = 0.32-81.6 s
Default value: 3 = 1 s
- > channel 006 (comfort-flash)
Number of flashing cycles for comfort flashers (highway)
Range of values: 0 - 5
Default value: 3
- - > channel 007 (wiping wash mechanism)
Number of wipes on spray.
- Range of values: 0 -?
Default value: 5
{combination instrument}
Controller coding
STG 17 (combination instrument) select
??xxx: Extra options and optional extras
+00 - no extra options
+01 - Brake lining wear announcement
+02 - Seat belt warning
+04 - Wiping water level warning
+08 - does not occupy
+16 - Activation clock in MFA
xx?xx: Country selection
0 - Germany (D)- metric 24hr
1 - Remainder of the world (RdW) ???
2 - THE USA (US)-imp
3 - Canada (CDN)- metric –12hr
4 - Great Britain (GB)-
5 - Japan (JP)-metric
6 - Saudi Arabia (SA)- metric –24hr- Speed chime at 120km/h
7 - Australia (OUT) – metric
- > channel 30 (tank fuel sensor adjustment)
The base value is 128 now can it in 1 ohm steps adjust, the respective maximum values is 120 and/or. 136.
- > channel 50 (going away barrier)
Login for the adaptation of the going away barrier, combination instrument to the engine expensive equipment. (??)
{comfort system}
Controller coding
STG 46 (comfort system) select
Central Locking (4-window):
00258 - Single door opening
00259 - Total door opening
- > channel 03 (auto-LOCK)
The vehicle is locked at a speed of 15km/h (0 = OFF; 1 = ON).
- > channel 04 (auto-UNLOCK)
The vehicle is locked at a speed of 15km/h and unlocked after to taking out the ignition key (0 = OFF; 1 = ON).
- > channel 05 (interior monitoring disconnection)
Connection of starting from of the interior monitoring with twice operate of ZV (0 = OFF; 1 = ON).
- > channel 06 (unlocking horns)
Unlocking is confirmed with a short acoustic signal (0 = OFF; 1 = ON).
Needs factory alarm
- According to legislator in Germany not certified.
- > channel 07 (locking device horns)
Locking is confirmed with a short acoustic signal (0 = OFF; 1 = ON).
- Needs factory alarm
- > channel 08 (unblocking flashing)
The turn signals are operated when unlocking (0 = OFF; 1 = ON).
- > channel 09 (bolting device flashing)
The turn signals are operated when locking (0 = OFF; 1 = ON).
- > channel 10 (alarm horn)
Land tuning of the alarm horn (1 = remainder of the world; 2 = Germany; 3 = GB).
Affects kind, length and volume of the alarm tone (legal guidelines consider).
x??xx: ESP (electronic stability program)
Note: Over this place it is specified whether the guidance assistance has its own guidance angle sensor, or whether via CAN from the ESP will receive the signal.
01 - no ESP 12 – ESP xxx??: Program type
10 - Normally (heavy vehicles)
30 - Comfort (heavy vehicles)
40 - Normally (light vehicles)
50 - Comfort (light vehicles)
60 - Mobility assistance
Nice one Bas, I'll add some of those ones you sent me to my website when time permits.
Probably it would be better to simply link to the original site you got the info from, instead of copying everything without a note about the source. Biggest problem with the way you are going is, you will never notice smaller updates and I doubt you are "updating" your copy regularly - which results in wrong/old information provided to the community.
:thumbdwn:
I do update regularly actually and always welcome new ideas or notes for correction.
All information is provided in good faith on an 'as is' basis.
What about setting up sth. real instead?
http://wiki.ross-tech.com/index.php/Skoda_Fabia_%286Y%29
You will find a lot of the stuff which is currently on my original website their in a while and you will also find more than that, so it would be "thankful" to place links instead of leeching knowledge and work without a small note about the source.
I'm sorry if by starting this thread, I seem to have upset anyone. As you can see from the very first post - I acknowledge the source. Elsewhere on this forum I mention Sebastian at openobd.org as a wonderful resource. He has helped me several times by email - and is an expert non=pareil in this complex matter.
I only wished to point out a great source of info. With over 11,000 members on Briskoda.net I only wish that an English Language version would be available. Babelfish does not do this valuable info a proper service.
I really feel that Briskoda.net would be honoured by properly approaching this gentleman to see if he would be so kind as to provide a thread resource specific to our cars vag-com setups.
I hope you are not reffering to me with this statement.
I am not comfortable with the direction this thread is heading.
I consider Stu a friend - we've had more than a few msg's back and forth and I wouldn't allow anyone to say anything less than complimentary.
The purpose of this forum is to provide information to members in a friendly manner.
I would remind newer members that according to forum rules, any personal insults will result in banning.
All the best,
Bas
Thanks for the info... There are a couple of items I might consider, such as the amount of wipes when using the washer and different alarm tone.
Thanks again.
Not me, so this wasn't meant to you. You didn't actually do what I discribed, so you don't need to feel guilty here. I apreciate your efforts in wanting a translation and actually doing one, even if it's just babelfish.
....I only wish that an English Language version would be available.
This is what we are working on and we are looking for volunteers that are willing to provide some information from their cars, only "problem" here is that a current (512.4+) VAG-COM version would be needed. Even though you don't have the chance to use the latest versions, you can help with providing comments about the information or even providing Auto-Scans and such things, so we can proof the correctness of the published stuff.
Partly yes, but I don't think we need to discuss this - everything is said, so let's do the "everyone is everyones friend" thing now. :)
Same here. Problem is I've seen to many people simply leeching stuff without even thinking about mentioning the source, so I might be a bit prejudiced on that topic.
Anyway, think about the offer...!;)
Firstly you are assuming that the knowledge published was leached, possibly from openOBD.org and secondly you also seem to be assuming that every access code relating to VAG vehicles is the intellectual property of that website.
Whilst I will agree that openOBD is a fantastic resource, and I congratulate you on it's content, I do take offence at the comments you make above regarding my website. It seems we will have to agree to disagree and continue in our own seperate ways.
Do keep up the good work and in the future should you you wish to share information with me I would gladly include the necessary credits.
