Minor Cosmetic Bubble in Vinyl Trim Piece
Does anyone have any suggestions on how to fix this minor trim defect. It's at the top of the Estate tailgate and looks like a trim piece that's had vinyl applied to it rather than paint.
It's not a big deal at all, but if it was easy to fix then I'd give it a go.
Can't see how the trim piece is attached - no visible fixings inside or out.
I think they have just left the protective cover on from new, just peel them off. My car is white and those parts are gloss black.
I suspect the dealer forgot to remove them.
Edited by nebrog23
  • Like 2
Really !! I never even thought of that. It does make sense - the vinyl does look a bit cheap and nasty.
Yes it will look much better with it removed
Yep - it was the just the protective vinyl covering !
It was just because the car was white that I thought it was meant to be that colour too.
Problem solved ! Thanks guys
So now check the rest of the car.
Have you reset the Tyre Pressures and the TPMS?  Best check wheel bolt tightness, bolt covers all there etc etc.
PDI must have been a bit rushed then any checking of the 'valeter / fitter / cleaners' work maybe not done...
