ABS compatibility with ACC
Hello guys,
recently I was able to get the round type of ACC for my Octavia MY2016 and I was thinking, that my ABS is compatible with ACC.
ABS: SW: 3Q0 907 379 T
         HW: 3Q0 907 379 C
ACC: 5Q0 907 541 P
On ACC I'm getting error FAULT_TSK_IRREV_FAIL and also FAULT_TIMEOUT_ESP_21, which should be problem related to my ABS?
In ABS and engine is just error, that something in Control Unit in the Drivetrain is wrongly codded.
I found out, in ETKA, that my ABS 3Q0 907 379 T can be with PR 8T0, 8T2 or 8T5 and as far as I know - 8T0 without CC and ACC, 8T2 with CC, 8T5 with ACC.  Based on that, I thought, that my ABS can handle ACC, but the error in ACC unit is telling me oposite?
I was also not able to set in ABS, that ACC is installed instead of CC - I don't know, which byte change and how.
I'm using ODIS for this.
Can anybody help me with ABS coding? Or my ABS is not compatible with ACC at all?
My current coding of ABS:
1C07629114210973007D060541CA243846289000608224F22041F070C082
AFAIK ACC has a different FeC code to CC, so it's not just an issue of ABS compatibility...
