Usb c rear
Hello,
i need your help. I have 3 children, and on long journeys the rear charging plugs are a necessity.
were i cand find this part for my scala?
Might have to be factory fit
I'm sure the factory. does anyone know the codes, or has anyone seen these pieces somewhere?
Hi
3G5 035 954A
thank you man
Its about €40 from Skoda-parts.  No idea if the wiring will be in the car for it (or enabled) as its a factory option.
Edited by Tarby
Hi, I'm very interested in this. Did you manage to install the USB ports? Was the wiring there?
  • 8 months later...
no one knows it there is a cable to connect the 3G5 035 954A ?
Description of part says with integrated reducer so I suspect power only and no data link .
If it is not installed in the factory, there is no wiring in the car for the rear usb port. Probably the original soluition will cost a lot for your need. Basically a hub like I attached will solve your problem. You can easily stick ( with double sided tape) it on the place which created for rear usb port.
Since the lighter connection placed below the armrest, it is easy to make the 12V connection.
  • 4 months later...
Rear USB ports are for CHARGING ONLY and if not fitted wont have any cabling to them
You also need this part to replace type c ports. 654 863 916
There is no data link for the rear USB's, it is only for charging. There are solutions to connect it to the 12v charger. This is plug and play.
See for example this for the Octavia/Kodiaq. The cable should be generic.
Auto Interieur Rear Dubbele Usb Adapter Charger Socket Armerst Usb Kabelboom Voor Tiguan 2 MK2 Teramont Octavia Superb Kodiaq|Cables, Adapters & Sockets| - AliExpress
Edited by jesse_s93
