Glow Plug Order (1 2 3 4)
I’ve got a glow plug 3 fault coming up. Is it as in looking at the engine left right?
I'm sorry I don't know the ansqwer but,  If you have a multimeter you might get the answer by checking the resistance of the glowplugs and see which one differs from the rest?
Good luck
Good luck
Indeed resistance should be less than 1 Ohm. You can usually measure in-car. Touch the connector tip and the body near the hex-nut ...
