Cheap steelies wanted
Looking to get some cheap 16" steel wheels to put some track tyres on for this summer, any idea on where i could get them and at what price?
I've been looking for the same (16" steelies), although not for track. If you find a source would you mind letting me know?
Ta :thumbup:
(and :bttt: )
I've got a set of 15" steelies off an Octy if you get stuck...... make me an offer ;)
Brakes won't fit under :(
(Suspect same for Hellfire)
P.S., Hellfire: is that a turbosnail in your avatar?
P.S.' date=' Hellfire: is that a turbosnail in your avatar?[/quote']
288mm won't fit under? if not then 312mm definately won't :eek:
Yes, that is a turbosnail :)
Or the way I saw it, speed of snail turbo referring to the lag time for it to come on boost.
I have 312mm brakes. And the car's 4 years old, so :eviltongu S. UK ;)
Yes' date=' that is a turbosnail :)
Or the way I saw it, speed of snail turbo referring to the lag time for it to come on boost.[/quote']
I just wondered (actually, I've wondered for *ages* just never asked) whether you knew it was an actual species? *Clicky*
Anyway, back on topic :rolleyes:
weller
you kow those tasteful white things you see on beetles and kitcars
I think (some) Bora steelies are 16in.
will 312mm brakes fit under 16" steelies?
The old Octy vRS Estate came with a 16" steel spare wheel, so i'm guessing yes.
I've got one 16" steel that used to be my spare just kicking about, if you get 3 more like minded people you are more than welcome to it
how much delroy?
Have you tried the sapre over the 312mm brakes, if so they are only
Breakers are the best source, a lot of skuds have steel spares, shouldnt take long to find 4 & as no body wants steels about £10 each should do it, you might even get some half decent tyres to trash
That idea is basically to spend £40 ish on some steelies, put some ****ty slicks on, and enjoy 2 weekends at elvington which will no doubt will the tyres due to the surface.
You can have the wheel for free but you'd need to arrange collection as I'm in Kent!
