Columbus retrofit (from Bolero)
Hi,
I have Bolero and Canton system with Telematics electronic.
Can I retrofit Columbus?
I would like to buy Columbus unit and display with CP off and enabled all Swap function.
In this case the system plug and play? Because off the Bolero not a navigation unit and I think my GPS antenna connects directly to Telematic system.
Anybody did the same?
  • 5 weeks later...
On 22/05/2020 at 18:21, Amarton said:
Hi,
Hello I'm trying this myselfe waiting for the radio to arrive.
https://www.drive2.ru/l/551367424130155525/
Here is some help.
Thank you. This is very helpful but I don't speak Russian the Google Translate helped but there is some misunderstanding.
I don't want LTE function.
The unit what I planned to buy  will be full activated including external GPS source.
If you have progressing your project please share it. :)
I retrofitted the Columbus unit.
Everythink is working fine but there is a GPS open failure in DTC.
The cheap external GPS antenna is working well, but the failure in DTC disturbe me.
I have telematic system with GPS. Can I use this GPS (coding or HW wiring) to Columbus?
  • 2 months later...
Hi @Amarton I am just doing the retrofit from Bolero to Columbus, I see that there is GPS connection already in the roof aerial, so I guess it is for Telematics. I see in the electric diagram that you either connect Telematics or infotainment unit to the aerial, but could not find how they both can coexist. Were you able to solve the problem, I would love to go the original way.
