Does not start after a while
Hi I am having a Skoda superb 1.8 TSI automatic Hi I am having the Skoda superb 1.8 TSI automatic and When I tried to start the engine after moving some distance the engine overheat and the engine does not start the engine only starts when the Indian cools down in that situation I have to open the bonnet for a while and let the heat out then only the engine starts otherwise the engine start and then suddenly switches off The main issue is the heating part I don’t know why the car heats so much on travelling a very short distance as well and when the heat is laid out from the bonnet the engine suddenly starts normally  Please to help me by letting me know that why there is such high heat in the engine And this only happens when I turn off the engine and then try to start it otherwise it does not switch off automatically while moving for a while it only does not turn on after I am myself switch it off and then try to start it after like 10 to 15 minutes
Does your temp gauge behave normally, or does this show overheating???
Do you have coolant in the system and is it to required level???
Hi tilt The temperature in the gauge is normal and the coolant level is also at the required level nothing I’m normal is shown in the MFT on the speedometer like the car overheats and the temperature in the gauge is also normal
