Monte Carlo Tech left indicator fault
Hello,
I am new to the forum. I have owned my Fabia 2 Monte carlo tech 1.2 petrol on 13 plate for 2 and a half years.
A fault with the left hand indicators has developed whereby all left indicator bulbs remain on static while driving and when ignition is switched off. I have located the corect fuse to remove overnight to stop the indicators emitting and prevent battery drain. A warning light on the dash displays while the fuse is in. It has been identified that it is not a blow fuse or relay. The problem started one day and then disappeared for a few days and returned and so now it's a perminant fault and not intermittant. I have taken it to my regular local garage who have examined it and told me that the problem is to do with the ECU and not something they can fix and that it may have to go to Skoda dealership to be rectified. They have implied that it could cost alot of money and I don't have dealership money.
Please can somebody who may be able to identify with this problem point me in the best direction and let me know what options I have?
Many thanks,
Matt
What warning light is on ?
Start the car, then try messing with the indicators and turning lock to lock so the colum cancels the switch, it "may" just be a stuck stalk switch.
Do the hazards work ok ?
Hi,
The bulb failure warning light comes on. All indicator bulbs work. I tried your suggestion and that doesn't work.
I've noticed that with the fuse in, the right hand indicators work as normal. The ticker sound is faster than normal with or without the fuse in. The hazards only flash on the right hand side and the left remain on static.
If I drive with the fuse out the brake lights do not work.
Matt
Fuse 49 is for turn signals only, so not sure which your pulling.
I would not recommend driving without brake lights.
