Help. Full beam headlights not working
Finally changed that switch gear. Replaced it with a new extremely expensive OE assembly, in fact I pretty much did it twice as I fitted the lower cowling incorrectly the first time round, had it rubbing against the steering wheel, so had to take the airbag and wheel off again.
Struggled with detaching the thing directly behind the steering wheel, which is attached to the switch gear assembly, 4 easy tabs and one silly clip on the left which took some time to release (by squeezing the body of that thing) I got it into my head I should push down the recessed tab, which didn't work.
Full beam works properly now which is a huge relief.  Next some work on the rear brakes to try and improve the hand brake then the dreaded MOT early next week. The torx M10 nut seems a bit soft so I can see why they recommend a new one
Thanks all for the correct diagnosis regarding that switch assembly being the problem.
I found this,though the assembly is different,remarkably an even newer model, my one  looks like it too can be taken apart, so I'll have a go and see if I can fix it , like this guy did
Skoda Fabia Windscreen Wipers Stuck On
  • Replies 100
  • Views 22k
  • I've order a 2nd hand Stalk for £24. Just waiting for it to be delivered. Then I will decide if I will fit it or get a garage to do it 0   All depends on price as would need to buy some tool
  • UrbanPanzer
    UrbanPanzer
    yes the top cowl just clips off, carefully prize it apart at one side.   So if you do that, hopefully there will be a sticker with the number on it just on the top.
  • Breezy_Pete
    Breezy_Pete
    I would definitely advise looking at the part number on ones existing part before ordering anything, if it's visible just by popping off that top cowling.   There are still other part  numbe
