B pillar trim removal ?
Hello,
I'd like to remove the B pillar trim on my 2017 combi as there is a rattle coming from behind it that is doing my head in. It's more of a knock than a rattle, to be fair, and it only does it when the ambient is warm. The sound is at about headrest level and it didn't go away when I locked out the belt inertia stop. I wondered if there it was the metal loop that the best passes through that is contacting with the pillar somehow.
I'm more than a bit annoyed with rattles on this car, to be honest - my Mrs' 2014 car has done 50k with no rattles at all yet mine (which was bought on the strength of the build of hers) has got a rattle from the dash on the drivers' side which seems to be active when the outside temp is around 7-12 deg C (which goes off if the internal temp goes higher/I apply pressure to the dash from the flat side that is normally covered by the closed door) and then this other knocking from the pillar that appears at around 13 deg or higher! Of course, I bought the car in November when it was cold and there were no rattles or knocks on the test drive I had. The car has also been back to the dealer as there's another knock that comes from what sounds like the base of the passenger side B pillar that only occurs when going over rough road surfaces (which is anywhere these days) when it's very wet (!) They didn't find anything, unsurprisingly, and had a pry bar in the suspension but found nothing, too - in fact, the guy said, "If this car was MOT'd tomorrow, it'd fly through."
Does anyone have any experience of doing this and/or a guide for doing this and/or a picture of what is behind the pillar?
Any help is appreciated.
Cheers.
Thanks for the information - that's great.
Can you tell me what the circled arrow means? Does that mean to push this tab to the left to get it to pop off to access the screw?
I've got a trim removal kit - can you recommend the best tool / way of getting this off or does it just come off easily once the screw is out ?
Also, what is the other circled item, please?
it is a picture from the workshop manual. the part in the ring is just a "fuse" so that the part with the word airbag does not fall out
