Removed and refitted wheel now really stiff and won't move!
I removed a rear wheel to check out the rotors and pads although I didn't remove anything else just a visual inspection.
So I put wheel back on and removed jacks etc and start car and I attempt to reverse and I get a very heavy resistance / sticking from wheel. I just apply very little pedal to accelerator I didn't even move car but it's obvious there is some serious resistance.
I don't want to force it incase something breaks up.
What is likely happening, can you over tighten the wheel nuts or does the security nut need to be in a specific hole. Basically I've not put the wheel back on correctly I think?
Any ideas?
Excellent!
Thanks for sharing :D
  • Sponsor
Many of us will have done something similar or worse, fair play for owning up. 👍
Quite a silly mistake. We might have laughed if we hadn't done something similar before :)
Having no short term memory and being blind to the left side  I do it pretty much everytime I work on one of my cars (sloping drive) the first time my reaction was just like the OP's, now I know immediately whats up.
Edited by J.R.
On 04/08/2020 at 15:27, Aj77 said:
Schoolboy error. Forgot to remove wheel chocks I'd set on the other wheel. 😂
When I read the first post I was going to suggest that as a joke - albeit a logical thing that sprang to mind.
  • Sponsor
I came close to topping this just now.
Aimed to change a set of steel wheels with legal tyres onto a friend's Golf with neither, only to be thwarted by not having thought about conical- vs radius-seated bolts. Rapidly realised that the first conical-seat bolt to come out meant mission abort.
Broke the bad news to friend then cleared away tools and wheels, agreeing to try to source a cheap set of suitable bolts and revisit then.
Most of an hour passed before I remembered to go back and unchock the back wheels...
