Dual Mass Flywheel 1.4TDi 105
Does anyone know if there was ever a recall for the DMF issue on TDi Fabias? If not, are they repairable? I'm getting a lot of noise when lifting the clutch and when depressing it.. it is slowly getting worse. I've had it looked at by a local garage (see video) and you can see the play in it shown when he videoed it - almost as if whatever holds the flywheel in place - presumably some sort of retention spring has now worn away somewhat.  Now he said he couldn't get a DMF replacement as no-one stocks it (I was a little dubious about that - but couldn't argue at the time for not knowing 100%).  He said he could convert it to a solid flywheel, but then the engine will need a recode, which he couldn't do - only Skoda could do.  Now, this is where it gets really bitchy.  The Skoda dealer where I bought the car said "we can't guarantee the mechanics quality of work, so we wouldn't recode it if he did it." Which is their way of saying we want to charge you a fortune for the work rather than a cheaper rate that he will do it.  There is no goodwill gesture as the car is now older than 5 years old and out of warranty.  Although the noise from the clutch did start under warranty, but they said at the time "it's normal" and "there's nothing wrong". Both of which I took for a bit of fobbed off response.  Given the water pump issues I had previously, I've lost all faith and trust in Skoda and this is my last Skoda I will ever own.  What I am asking though, has anyone had theirs repaired and if so by who, how much etc.?  I was hesitant on the switching to a solid - given it would probably rip the gearbox to pieces without the recode.  Does anyone on here know anyone who could do the recode if I got my local garage to switch it?  Any help appreciated.. I am North West England based, so looking for someone within a decent radius of where I am.  Thanks.
  • 2 months later...
This issue is resolved and thread can be closed down - 3 piece clutch kit and DMF fitted by a local clutch specialist with a 2 year guarantee for £579+VAT.
