Keys and User Accounts
Skoda Octavia Scout mk3 2019.
Hi, I'm after some advice. I have set up two keys to two different user accounts but every time I put a key into the ignition I have to manually select which Driver I want. How do you set it up to recognize that key 1 should set it to Driver 1 automatically and key 2 should set it Driver 2 automatically?
In the personalisation settings, set the keys to manual and assign them to each profile.
Hi Sasha, yes I did that but it still kept forgetting them. I've had a play trying different things such as turning on the ignition after I had programmed the keys and that seems to have sorted it.
Did you do the enable bit at the end, you need to press the unlock button on the key in the ignition with the ignition on
