Rear numberplate lights
I have recently changed my rear numberplate lights to LEDs & when I tried to the lights on, I get a warning on the instrument cluster saying check numberplate lights.
I know that this is because the old bulbs drew 10w each & the new ones draw about 2w each so it thinks they have blown.
Does anyone know a way to stop this?
Tia,
Gareth.
You either need to get canbus friendly bulbs or code out the light checking with such as VCDS.
Ah right, thanks, will have a look
@GazzaCarlin I've got the same design as them in my sidelights without issues...
Didn't realise they fit the number-plate, I will have to try them.
I've been very lucky with my selection of led lighting as they can be hit and miss depending on the honesty of the seller or / and manufacturer.
Hmm, how strange!
Yes, they are the W5W type.
You can say that again!
I may have to but some more to test if I have a dodgy one
I will look see if the ones I've got are still in my 'purchased' list, but I sure they aren't. Bought ages ago.
I had the same issue with a pair of LEDs that I put in.
Ended up buying these as entire replacement units and no faults so far:
https://www.ebay.com.au/itm/183251881190
I also got some complete replacement units for mine:
https://www.ebay.de/itm/174143815622
No errors and they look great. Really bright and a nice even light spread.
Cool, will have a look at them
The replacement unit ones are the way to go, and coding them properly allows them to be run without load resistors which is infinitely preferable.
On 02/09/2020 at 23:52, GazzaCarlin said:
How have you got on with these? Any errors at all ? I bought some "error free" ones which aren't.. Might get these.
I still had to put load resistors on! Other than that, they are nice and bright and easy to fit
Meine came with resistors too. So I fitted them anyway and they've been perfect with no errors. Lovely and bright but look factory fit as the light spread is very even.
