Timing Belt Replacement
Changed timing belt on new Roomster 1.9 TDI PD, BSW, 59800 miles, 6 years 10 months belt run.
Tensioner not on original setting due to belt stretch? Belt was a Dayco (VW marks) all parts in good condition. Replaced with Gate's, tensioner made in Turkey, all previous made in Canada!
Next time will consider changing with Dayco. I have always used Gate's for the last 30 years.
Tensioner will shift even after you rotate the engine to check the new belt is OK, this is even more true for newer 1.6/2.0 diesels.  Yes, the belt will stretch a little with age, but half of the difference shown could be normal tensioner swing.
I replaced the belt and the water pump on my Roomster 1.6TDI a year ago due to badly leaking water pump, made 3 attempts to set the tension as per factory service manual and always it shifted to different to what I had set after rotating the belt.
Only then I found online a later date factory service manual telling me not to bother about it.
Regarding Dayco vs Gates vs other brands, any kit will do so long as it is undamaged. I ordered a beautiful Dayco belt+all rollers kit from amazon, good price, only on arrival the main tensioner roller had 2 deep scratches on the belt's running surface. Sent it back and went with INA kit and Dayco belt, not so nice but undamaged. 15k miles later still works fine.
