SDI tune...
Hi, Does anyone know how to obtain more power from the 1.9 SDI engine?:confused: (chips, exhausts, air filters etc., plus what power gains would be expected, if any?
Thanks terry007
K&N or green filter may help a little but apart from that it's very expensive for little gain
The SDI can be remapped, i have done a couple but as said gains are much lower than turbo cars. You would be looking at about 8% increase
can you not fit a turbo onto a sdi?
Not cost effectively - you'd need to re cam etc to open the valves longer to take advantage of the turbo - too exppensive when you can sell the car and buy the turbo'd one for very little difference.
If you're going to play with an engine, you should start with the best one available :thumbup:
If you're going to play with an engine' date=' you should start with the best one available :thumbup:[/quote']
As a general rule your correct however quite a few people who own a 1.4tdi for example enjoy the challenge of tuning the car & the performance from something which really shouldnt have that power.
That's a really good point, I never even considered that - I was thinking about the 'easiest' way to get the power, not necessarily the best or most enjoyable.
I can guess there's a really good sense of achievement doing that.
Or buy the best one available and then perform an "open engine transplant" :rofl:
Chris
Chris
Surely nobody would be silly enough to undertake such a task :rofl::rofl:
I heard an old wives tale that only people in the far south west attempted that kind of trickery :D
i drive a vehicle with the sdi engine at work everyday great little workhorse with over 110k miles on the clock........ vw caddy van thoght there was no need for more power untill i got my fabia...... nevermind the van will soon be replaced by a new caddy 2.0 tdi hehe
you can fit a powerbox The dragon one is good and cheap.
also an air filter.
as an alternative to the powerbox you could swap the injectors for highr flow ones.
it wouldnt be a good idea to do both you'd just make smoke.
rule of diesel tuning smoke =too much fuel.
so you add more air
