Sluggish cold start --- 1.2 TSI CBZA
Quick update - all plugs and leads changed along with the coil pack. Put some cleaner in and thrashed it about a bit, everything running great now. Glad the issue was as not as serious as some other people ...
  • Replies 50
  • Views 23.4k
  • Misfires, so 90% certain that it's one or more plug lead failure. Very common even at low mileage on pre 2012 engines particularly no. 3 lead which rests on or very near the turbo heat shield without
  • I had battery disconnected for half an hour perhaps.   Air filter is basically looking like brand new.
  • It might be as you say, the oil seperator not doing its job properly.   Check the pcv (positive crankcase valve) system is not blocked and causing over pressure in the crankcase.
