DPF Engine Warning light
1 hour ago, Davet30 said:
had you done any checks on the glow plugs yourself before you took it in e.g. resistance readings?  I'm guessing they changed all the plugs - (good practice)
No, aside from the fact it's a company car I don't know enough to start checking resistances or other checks so wouldn't know where to start.  I'll bear it in mind though if I get the same issue on our Yeti at any point, as that is mine and if I can fix it myself, all the better!
