Electric Boot opening and closing on its own in quick succession over and over
Does anyone have, or ever had this thing where the boot opens and closes super quick, over and over ... for 5-10 seconds?  Its random and is doing it on its own.  I was thinking maybe a fuse?
When I say quick, I mean .5 sec. intervals.  Open / Close / Open / Close etc ... for sometimes 5 up to 30 times.
Two things to note:  The first time I parked my car outside and also I used the remote warmer.  (last night it was about 5 C)
Hadn't happened to me before today.
Thank you for the feedback - stay well.
Best,
DB
Have you changed the bulbs in the trunk for led ones?
Hi Gabriel - had to laugh at that because yes, I changed the bulbs in the whole car to LED (including the trunk/boot).
What do I need to do to remedy the situation?
Best,
DB
1 hour ago, Vivooks said:
Hola Gabriel, tuve que reírme de eso porque sí, cambié las bombillas de todo el auto a LED (incluido el maletero / maletero).
¿Qué debo hacer para remediar la situación?
Mejor,
DB
It happened to me with the soffits of the trunk that come mounted.  They gave me the same failure when turning on the parasol light ... I removed those ceiling lights and put some Auxito bulbs from Aliexpress and I no longer have errors and it lights more powerful.
Mejor,
DB
open the roof of the trunk and put auxito of Aliexpress, they are expensive but very powerful and do not give fault.
I don't know if I can put links here ...
Funny you say that ... I had some LED's I bought here in Switzerland for 20 bucks a piece in there, and had no problems.
I purchased some more LED's from Ali Express and changed them because they are brighter, and then this happened.  Who knows! :)
I will keep monitoring it and if I need to, I will change back to the expensive LED's that are less powerful.  Maybe it was just a one
time thing because it hasn't happened to me since that day.
Thanks Gabriel ... much appreciated for the input!
Hace 2 horas, Vivooks dijo:
Es curioso que digas eso ... Tenía algunos LED que compré aquí en Suiza por 20 dólares la pieza allí, y no tuve problemas.
Compré algunos LED más de Ali Express y los cambié porque son más brillantes, y luego sucedió esto. ¡Quién sabe!:)
Seguiré monitoreándolo y, si es necesario, volveré a cambiar a los costosos LED que son menos potentes. Tal vez fue solo uno
Cosa del tiempo porque no me ha pasado desde ese día.
Gracias Gabriel ... ¡muy apreciado por el aporte!
sure they are the trunk ... You are welcome!
1 hour ago, MartiniB said:
For trunk: Exceptional power of light.
€ 3,37  32%OFF | AUXITO 2x T10 W5W LED Canbus 194 bombilla para Nissan Qashqai hoja X rastro Tiida nota Almera coche Led Interior luz en el maletero 6500K blanco
https://a.aliexpress.com/_9QaNY7
For interior (all of them): perfect color and power, neither much nor little.
€ 2,56  12%OFF | 10 Uds T10 W5W bombilla Led Auto luz Led Interior para Skoda Octavia Yeti Roomster Fabia rápido Superb KODIAQ Citigo
https://a.aliexpress.com/_AnsH0L
For the rear indicators: too much power of light but good color, im looking for another lamps less powerful.
€ 11,70  40%OFF | 2 uds., PY21W LED Canbus BAU15S, LED sin errores, sin Hyper Flash amarillo ámbar, 7507 bombillas LED para luces de señal de giro
https://a.aliexpress.com/_9ydlLZ
for the front fog lamps ... they do not have a cornering function with dimmed off, but perfect color and power.
€ 7,80  38%OFF | 2 Unids H8 H11 HB4 9006 HB3 Led 9005 Luces de Niebla Del Bulbo 1200LM 6000 K Del Coche Blanco de Conducción Diurna Auto de La Lámpara Led de Luz 12 V 24 V
https://a.aliexpress.com/_AZgG4B
Sorry for the link in spanish.
Edited by Gabrielem
3 hours ago, Gabrielem said:
I got a similar error from Aliexpress ...
what are you talking about?
i have no errors and my bulbs are completely different
can't even imagine how wrong is light beam from your fogs, worst choice i have seen
3 hours ago, MartiniB said:
¿de qué estás hablando?
no tengo errores y mis bombillas son completamente diferentes
Ni siquiera puedo imaginar lo mal que está el haz de luz de tus nieblas, la peor opción que he visto
do you have better options?  share them with others as I do ...
Open link which i posted above,
that tread has pictures of bulbs and links to Ali
Hace 40 minutos, MartiniB dijo:
Abrir enlace que publiqué arriba,
esa huella tiene imágenes de bombillas y enlaces a Ali
these gave me problems.
€ 6,00  37%OFF | 2 uds. Caja de guantes de cortesía LED sin errores bajo la puerta Luz de pie para VW Touareg Tiguan Eos Passat SKODA SUPERB 2016-
https://a.aliexpress.com/_AFBCgT
