No battery warning light/dead battery - 1.9 tdi
Broke down due to flat battery as alternator wasn’t charging but had no warning light.
Battery light isn’t coming on with ignition and then shutting off after the engine is started, as it should. It illuminates if I do dash output tests with vcds but other than that, nothing.
I’ve replaced the alternator but it’s not charging unless it’s revved over around 2k rpm, continues charging at idle after that.
vcds scan isn’t coming up with anything related to alternator load signal as I was expecting. Do these suffer with the same fault as the mk1 with the plug near the starter motor? Anyone else had this fault on theirs?
  • Sponsor
It's the blue wire to the alternator you want to check, not the load signal one. Not sure how the wiring's done on a mk2, have a look.
Cheers. Blue wire is showing battery voltage. Browny orange one is showing around 3v. Not sure what they’re meant to be?
Hopefully the weather is better tomorrow and I can have a proper look underneath.
The faults showing up in VCDS scan seem to relate to a faulty heater control panel but just wondering if signals are sent and communicate ‘through’ this panel?
Just been and checked the connections near the starter that the mk1 suffers from but they look good. I got mixed up yesterday, the blue one had the lower voltage on it, not the brown with the red tracer, so I’ve got low voltage on the blue if I should be seeing 12v for the battery light. Still wondering if it’s a fault in the heater panel causing it as I think these are part CAN?
Ignore the heater stuff, it's not relevant.
  • Sponsor
What was happening at time of voltage measurement, where was the measurement done?
i.e. did you measure at alternator connector? With it plugged in or unplugged? Engine running or just ignition on?
I can't imagine the HVAC module is in any way related.
With just ignition on, the brown with red tracer was showing 12v and blue just over 8v at the alternator plug. The blue was unchanged when running but brown/red was showing 13.8v after I gave it a blip of the throttle. I was getting the same figures at the other side of the plug near the starter and there was no resistance showing in the short run of loom between there and the alternator. Not sure how to check with alternator plugged in? This was with the alternator unplugged.
The wiring looks good after taking the small black Flexi conduit of up to the point where it joins a larger loom under the battery. Looks like it runs along the chassis leg then but can’t see a lot with the battery and air box there.
I was thinking I should but had other cars where components are a ‘pass through’ for other systems, so one thing failing can take out a few.
  • Sponsor
If it were useful to do so (not in this case) you could measure while the connector is plugged in by stabbing a needle through the wire insulation and connect your meter probe to the needle.
Your blue wire voltage definitely looks too low.. I'd expect about half a volt less than ignition 12V.  What year is this Fabia? And what is the resting voltage across the battery terminals at the momnet?
It’s a 58 plate BSW motor. Resting voltage of the battery is 12.8v
  • Sponsor
I'll have a look at the circuit diagrams later; but I'm almost certain that the blue wire originates from the Central Electrics module above the accelerator pedal.
  • Sponsor
Does the car have DRLs?
The wire goes direct from that 2-way connector pair at the gearbox to pin 9 of connector XS4 at that module above the accelerator pedal.
But there's a connection also to the "Day driving lights relay" that I've not come across on mk1s. Potentially if that relay is poorly it could be pulling down that voltage, as could any partial short like rainwater affecting cracked insulation somewhere in the engine bay for example.
Cheers for the help! I’ve had the battery tray and air box out and checked the wiring along the chassis leg up to the bulkhead but there’s nothing obvious wrong. Looks like it goes up into the scuttle rather than straight through the bulkhead.
The car doesn’t have DRL’s. I’m just trying to figure out how to access the module above the pedals now. I’ve removed the polystyrene cover but looks like I might need to remove the lower part of the dash and move the module to allow for the plugs to be removed.
Is this the one?
Edited by PD_Roomster
  • Sponsor
Yeah, that looks like the one.
With alternator plug unlugged (as well as that plug), measure resistance to chassis ground from that blue wire.
Not getting anything when taking it to ground so don’t think it’s shorted anywhere but not getting any continuity if I go end to end on it either?? Showing 11.9v at the blue cable on rear of the brown plug above, but 8.2v at alternator socket.
I’ve just ran a piece of cable straight from the blue wire on the brown plug to the alternator and the battery light is now coming on with the ignition like it should. I didn’t start it to see if it extinguished as the air box/maf and battery are still out of the car and it’s now gone dark. I’ll carry on with it tomorrow.
Pulled the scuttle covers but all looked good as far as the loom goes in there. Ended up running a new cable from the plug under the dash to the alternator along the original loom route.
All seems to be working as it should now, light comes on with ignition and goes out once started 👍
  • Sponsor
Good work!
