which prt of exhaust pipe do i need?
hi guys,
my car has been fitted with a modded exhaust pipe which makes it sound very loud. i really want it back to normal.
question is, which part of the exhaust do i need to buy? the muffler bit(bit sticking out of the car on the back) or the whole lot (complete exhaust pipe?)
many thanks
What car is it?
17 hours ago, sepulchrave said:
What car is it?
hi
i have a skoda fabia mk2 2008
What colour is it?
black magic
3 hours ago, froggy8 said:
black magic
I was kidding, we need to know which ENGINE it has.
hi
its a bzg, all my info should be on my avatar.
i am guessing all i have to remove is the muffler part, am i right?
do i just remove the muffler?
also it is really loud, im not even sure if its blowing or that is just the way its meant to sound. i will upload some pictures and videos, hopefully someone can help me.
  • Sponsor
The one you linked last night is for a 1.4 engine, it says.
TBH your best bet is to take the car to an exhaust place and ask them which bit is making the noise, and to replace it with standard if it's non-standard or leaking.  Buying the part yourself will save you nothing unless you can fit it yourself, and it's not really the weather for that sort of thing. You just have the added risk of changing the wrong section, and adding new leaks at the joints if you DIY it.
[url=https://postimg.cc/WD3pZvj5][img]https://i.postimg.cc/WD3pZvj5/IMG-4055.jpg[/img][/url]
[url=https://postimg.cc/w1FT3vKt][img]https://i.postimg.cc/w1FT3vKt/IMG-4058.jpg[/img][/url]
[url=https://postimg.cc/VJzkYthQ][img]https://i.postimg.cc/VJzkYthQ/IMG-4059.jpg[/img][/url]
yeah i think it is best taking it to an exhaust experts.
<a href="https://postimg.cc/WD3pZvj5" target="_blank"><img src="https://i.postimg.cc/WD3pZvj5/IMG-4055.jpg" alt="IMG-4055"/></a><br/><br/>
<a href="https://postimg.cc/w1FT3vKt" target="_blank"><img src="https://i.postimg.cc/w1FT3vKt/IMG-4058.jpg" alt="IMG-4058"/></a><br/><br/>
<a href="https://postimg.cc/VJzkYthQ" target="_blank"><img src="https://i.postimg.cc/VJzkYthQ/IMG-4059.jpg" alt="IMG-4059"/></a><br/><br/>
Edited by froggy8
sorry for some reason, pictures arent showin gup
here is teh video.
Sounded a bit leaky. Put your hand over both outlets, with a nice thick cloth, and listen for the gasses escaping from along the pipe. It may well be a joint but could just as easily be a muffler/silencer part. I think you should follow Eino's advice, though and ask for a quote from an exhaust centre. The rear box will most likely be a little louder then bog standard too, so if you like it quiet, that'll want replacing too but is solid, may have a (Little) resale value.
thank yu, will try find a place local to me.
If you are trying to get a standard one beware of the cheap, bottom of the barrel variants. I got a midpipe and backbox for my fabia a few months ago and it had to be cut and rewelded to fit, even though it was the one for my car. Sounds nicer mind, a little more noise from the engine without being at all obnoxious.
  • 2 months later...
ok guys, the mechanic have changed the front exhaust pipe just over a week ago now. it started off quiet and yesterday its blowing at the front again.
can anyone tell me what has happened?
brand new pipe put on and its blowing again in same area?
