MK2 VRS Facelift 2.0 TSI
Does this model have a dual mass flywheel? CCZ engine.
Yes
Can this be converted easily when replacing the clutch, or best to stick with dual mass flywheel?
Not a cheap fix!!
16 hours ago, Awesam said:
I had mines replaced last year with a Sachs Performance Kit which has a single mass flywheel and I've had no issue at all.
SACHS Performance Clutch Module 883089000046
I changed the slave cylinder aswell.
Clutch Central Slave Cylinder (CSC) 613182654150 | SACHS (sachsperformance.com)
Do you get any transmission noise when at idle?
I was told by awesome gti that they are noisy and not for a daily car....
Strange I've never experienced it unless as the car had it when I bought maybe I've not noticed it! I changed it to a SMFW as I could hear a knocking with DMFW and the clutch was slipping.
Happy to take a audio or video send it to you to check it out. The only change I've noticed is with the dog bone insert.
I went for the power clutch which not  is only rated to 550 nm, the clutch pedal feels like stock and is great for a daily driver. The organic/race one is rated at 800nm and the pedal would be heavy.
Edited by Awesam
If you could that would be great.
