Are brakes on new vRS same as old vRS?
As above, just wondering really.
No. Not on the front anyway.
Not on the rear either.
Discs are different sizes and 5 x 112 PCD. Also rears are no longer vented.
Are the calipers the same?
Back ones are mounted on the leading edge of the disc instead of trailing so rears are different.
What size are the front discs now then?
I would assume that they are the same as on the VW Golf GTI FSI Turbo?
What size is that :confused: :D
312mm up front, 286mm rear.
So much the same up front (obviously, different pcd), while the backs are 3cm larger but unvented. Odd.
