Window Regulator replacement with Rivnuts
i have to do this too at some point...
did you use the rivnuts to put the door panel cover back on too?
thats my main thing... i dont have a rivetter, and i dont feel like buying one for one job.
that and i read somewhere here that the regulator rivet (i think) is a stainless steel one for the load it carries? maybe? its a while ago..
HI
When you say "door panel cover" do you mean the metal one I pictured here?
This is the part, I was told, was "the regulator". So this is the part that I secured with Rivnuts.
I purchased this as a whole part, including the track, the cable and the motor, so I did not need to rivet the regulator track on to the regulator panel.
This is on a Mk2 Octavia, I think Mk1 Octivia is a different regulator unit. The internal door panel trim (AKA Door Card) is fitted with some screws and a few clips.
The other side of this regulator panel (the inside) looks like this:
https://www.ebay.co.uk/itm/353189547441?chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=353189547441&targetid=1055001932367&device=c&mktype=pla&googleloc=9045641&poi=&campaignid=10204071303&mkgroupid=104953043274&rlsatarget=aud-629407027585:pla-1055001932367&abcId=1145987&merchantid=7410404&gclid=Cj0KCQiAifz-BRDjARIsAEElyGKLLlbJDP1VkTkcLhhA2e8KyLDpvPvZpNEYZ8Df3WPNsl3kHIsxVqwaAhbQEALw_wcB
The white plastic glass carrier runs on the black metal track and has a pair of cables which wind around the gear unit (white triangle bit), which is driven by the motor (through the panel).
The cables/plastic carrier/gear are available as a kit:
https://www.aliexpress.com/item/1005001562354481.html?src=google&albch=shopping&acnt=494-037-6276&isdl=y&slnk=&plac=&mtctp=&albbt=Google_7_shopping&aff_platform=google&aff_short_key=UneMJZVf&&albagn=888888&albcp=9604713100&albag=99283534296&trgt=296904913880&crea=en1005001562354481&netw=u&device=c&albpg=296904913880&albpd=en1005001562354481&gclid=Cj0KCQiAifz-BRDjARIsAEElyGJz0nOR8ugCgr8mA1Ivl0lbBHteINA69JRND7kUK0cIW81yanu33o4aAp6REALw_wcB&gclsrc=aw.ds
But as both the cables are sprung at the carrier end, they can be difficult to fit, so I opted for a used one, for ease.
It took me a total of about 5 hours including taking the internal trim off, drilling off the rivets, fitting the Rivnuts and re-assembling.
Good Luck
thanks.
i didnt realise the panel acted as the regulator too!! godamn it 🤦‍♂️😅
i thought it was just a metal panel instead of the plastuc sheeting they used on the mk1 which, while terrible in one way, was a lot more accessible for working through (as long as you took the time to re-seal it properly)
thanks for the links, they may be getting another sale added to their listing ;)
well, i have a new full regulator Panel with cable sets ordered. mine is the front left door.
go buy some rivnuts and m6 bolts next.
then... start building up the courage to tackle it :D
i have to say though, that rivetting the panel on has to be the stupidest way of doing that design?!?!
Edited by mac11irl
I agree with you about using rivets. At least Rivnuts are a viable option.
I would say the trickiest part is drilling out the old rivets and removing the two part, plastic dowels, which hold the glass into the plastic carrier(s).
Its one of those jobs which isn't technically difficult, just a bit fiddly, but having the Rivnuts means you can at least remove the regulator panel if needed, which you cannot do if you use normal rivets. Pushing the dowels into carrier can be a challenge, because you need to be careful not to press on the glass too much as you could break off the lower part of the glass which has the hole in it, which will be the weakest point of the glass, due to the hole(s)image.png.bba603848d6dddcb3a31d435185b6801.png .
Regards
Russ
I have looked at the Haynes manual, and the instructions for refitting the glass into the regulator, state that you should replace the two plastic "spreader plugs". Also, it states to fit the larger plug into the hole in the glass, then fit the smaller plug into the large plug. Then you should lower the glass (with both plugs fitted) and engage the plugs into the plastic bracket on the regulator. I had fitted the glass into the plastic bracket on the regulator, then tried to fit the plugs into the hole in the glass, but i found it difficult to push the smaller plug inside the larger plug, using the access hole in the panel.
thanks.
my rivnuts arrived last friday
and my new regulator panel arrived today :)
just need to get a pack of m6 bolts and then a few hrs to go and do the nasty...
Good News!
When you get your M6 set screws (Setscrews have thread all the way from the end to the underside of the head, bolts have a plain section under the head, then thread to the end), get some washers too. Make sure the screws are not too long. Mine are 10mm long, with a Torx T25 pan head (had some kicking about), but I would say 12-15mm would be better, to give a bit more thread into the RivNut.  I would advise to keep the head choice as low profile as possible (say 4mm max) to avoid it fouling the door card when it is refitted. Remember that the factory rivets would only be about 2-3mm above the surface of the regulator panel, but with a screw and washer, it will sit a bit higher off the regulator panel. I don't know how much clearance there is between the regulator panel and the door card.
Let me know how it goes.
If you use rivnuts without the setting tool then drill a hole in a piece of metal strip to hold as a handle to prevent the rivet from turning and you will make a much better job of setting them.
You will probably have something in your scrap bin, a repair bracket or even a piece of Meccano.
If you want to start using flush thinsheet nutserts (Avdels) then a setting tool is a must, they are a fraction of the price today that they were 35 years ago when I bought my Avdel set for £40ish.
Before you try and get the regulator off, you need to separate the glass from the regulator panel track!!
Assuming you already have the door card off, disconnect the motor plug, then remove the 3 Torx screws holding the motor and remove the motor.
Remove the black rubber grommet which is just below and to the left (in this picture, you can see the hole where the grommet was).
This will allow you to see the spreader plugs which hold the glass to the plastic regulator bracket, once you lower the glass - you can see the hole where the spreader plugs fit.
Using some straight circlip or needle nose pliers, turn the white gear where the motor was fitted, and lower the window glass. As your plastic regulator bracket and or the drive wire are broken (which is why you are doing this job) lowering the glass may be a struggle, or may be easy, just make sure the glass cannot fall, so use a dent puller on the glass, like I did, to limit the travel of the glass or ask someone to hold the glass.
When the glass is almost at the bottom of its travel, you should be able to see the spreader plug through the hole where the grommet was fitted.
Use a M5 x 70mm screw, insert it into the smaller plug, then pull it the plug out, then use an M8 x 80mm screw and repeat the process from the larger plug. This will separate the glass from the plastic bracket. You can now lift the glass manually by pulling it up, then secure it with some tape or a dent puller on the glass.
You can now drill the rivets out with a 10mm drill. Once all rivets are drilled out, you can extract the regulator panel downwards as the top of the regulator track extends a bit higher than the panel.
You can use a length of woor to support the window from inside the door cavity for extra security while you fit the RivNuts.
You can now open the holes out in the door panel (I would recommend a cone drill as above), then fit the RivNuts.
Fit the large spreader plug to the hole in the glass (the large plug has a groove around the middle of it which allows you to locate it centrally in the glass) then fit the smaller plug into the large plug.
Now offer the regulator into the door opening (remove wood if used), and adjust the position of the glass, to allow the spreader plugs to locate in the hole in the plastic bracket.
Once it is located, adjust the regulator (using the gear where the motor was) and glass position, so that the regulator can fit into the door panel (there are 3 or 4 large metal dowels on the rear of the regulator panel to allow the regulator panel to sit correctly.
Now fit the screws and washers to secure the regulator panel. Now fit the motor screws then re-connect the motor.
Run the window up to the top and hold it there on the switch and then do the same at the bottom travel. This will allow the system to set the top and bottom travel, and then the window will work with the "one shot" function.
Refit the rubber grommet
Refit the door card.
Good Luck
I just remembered that yours is the front regulator, so you will have two plastic brackets and spreader plugs to deal with, accessible through the holes circled.
Good Tip - I watched a few You Tube videos, some used a "handle", some didn't.
I didn't use a handle, and they worked fine, but I guess a handle would help.
It means that all the force is resolved axially as it should be, as you say it can be done without once it has nipped up slightly but the force applied will try to rotate the nutsert and would strip its grip if you fully tightened it, the handle avoids that or simply leaving the final tightening till the component is secured in place will suffice.
For flush rivnuts (thin sheet nutserts) a handle (good name) is essential but not as good as the correct setting tool.
