Wanted.
Good afternoon, I'm hoping someone can help.
I am looking for a wiring loom for the front foglights and drls for my retrofit on my Skoda Octavia MK2 2012. I have the lights, light switch, bcm and vcds. I have looked at kufatec website but they only seem to have foglight looms not the one with drls. Seems all the breakers cut the looms so no joy there. Willing to buy the whole lighting if its combined headlight and foglights loom. It must suitable for halogen lights not xenon. Thank you in advance for any help or advice.
Why not post an Ad in the Classifieds?
Thanks I will.
Given it's only a couple of wires, I'd suggest you make your own loom :)
The DRL connector is probably 1J0 973 722.
If I recall, the fog is H8 so there are plenty of connectors online.
edit:
I think the original fog connector is 3D0 941 165 A :)
edit2:
Replacing the front loom could be quite a challenge and there are a few variants depending on your car's equipment...
https://skoda.7zap.com/en/cz/octavia/oct/2010-663/9/971-971084/
Edited by langers2k
Thanks Langers2k I will if I cannot get an original.
Have managed to get a loom for a VW polo 6c which has drl and foglight connectors. I believe the wiring is as follows
Connector C pins 48 left and 49 right for drls.
Connector A pin 25 left fog light
Connector C pin 25 right fog light.
Just need to know the wiring from the light swith to BCM. There is an extra cable which is included with the loom.
Also the earth cable to chassis or negative terminal on battery.  Any advice greatly  appreciated.
I'd earth it to a suitable point on the chassis. That's how the originals would have been wired in.
As for the light switch, I believe it's pin 5 on the light switch to connector A, pin 21 on the BCM :)
Thanks Langers2k,  very helpful and much appreciated.
