Octavia Scout Mk3 Rear Suspension
Carslton, Karhunik – many thanks. So very helpful. Order placed.
  • Replies 132
  • Views 31.7k
  • To find out what springs were factory fitted, check the build codes or the coloured dots on the springs (if they are original).   For example, if you had build code PR-L30 or 1 grey do
  • Just as an update to my spring replacement last year: all good. Handling is great after 4 wheel alignment, sag has gone, and towing a caravan much improved. Brilliant advice on here as always. I’ll be
  • Long time since no update with my Scout chassis parts, but I ended up replacing all shocks and front springs in October 2023 after a clutch failure (was driven approx 270 000km at the time). Rear spri
Thank god i found this thread, because i'm almost pulling my hair out trying to figure out the right springs.
Vehicle Details:
Octavia 2.0 TDI (2015) 105KW (NR3 46C) - twist axle rear
Axle Load(As per sticker)
Front Axle : 1020Kg
Rear Axle-2 950Kg
Suspension PR:L29 ( i have the Rough road pkg, i live in india)
After shocks gave up(60K), i picked up Sachs
Front : 560277
Rear : 318203
I want to basically get the euro spec setup for the 2TDI, and i'm just not able to figure out what springs i need to pick up
from the catalog, i'm not sure if i should consider the L08 or L09 as the euro spec or something totally different )
It would be wonderful if anyone could help me figure out the part# from either Bilstien or Sachs to get the Euro ride height.
I dont want to lower or raise the suspension, i just want standard euro ride height .
Further Details.
i've upsized from 205/55/16 to 225/50/17 and final ride height is about 167.5mm . with a drop to euro spec(-15mm) i think i will at 152ish which is what i want.
Vehicle Details:
Front Axle : 1020Kg
Rear Axle-2 950Kg
Front : 560277
Rear : 318203
Further Details.
Octavia MK3 2.0TDI estate 105kW/143PS (FWD Front Wheel Drive) (rigid rear axle)
Standard ride height front springs (manual transmission)
5Q0411105GK
Standard ride height front springs (automatic transmission)
5Q0411105GL
Standard ride height rear springs (without towbar)
5Q0511121AF
Standard ride height rear springs (with towbar)
5Q0511121AG
When changing from increased ride height springs to standard ride height springs, change the front shock absorber buffers to ones that have a 70mm height. The increased ride height front shock absorber buffers are often 90mm in height, so this change will free up an additional 20mm in front suspension travel. The 70mm buffers are what the factory Octavia MK3 cars use with standard ride height suspension.
Octavia MK3 2.0TDI estate 105kW/143PS (50mm front shock absorber struts)
70mm front shock absorber buffer for standard ride height
1K0412303B
Edited by Carlston
Thank you very much @Carlston , this give me a very good heading .
one final doubt i'm having is the front axle load weight . the sticker on my car says 1020Kg(Front) 950Kg(Rear) and when i do some digging on the VAG part numbers .
Its showing up as PR:L06 .
what i dont know is if PR:L06 has the load capacity of 1020 or higher or lower. how can i find that out?
Does L07 mean its load capacity is higher than L06.
Could you please share, because i have to import these spring and i dont want to make a costly mistake.
I did a bit more digging,
I think these are the springs.
Can you please confirm
Front springs :B3 37-293215
Rear springs :B3 36-292936
according to www.skoda-parts.com for my 2016 pre-facelif octavia 5E5 scout 2.0 tdi 184 bhp the oem p/n is front 5Q0 411 105 HS rear 5Q0 511 115 AL
L06 is 5Q0411105GL, so it would make sense to fit these front springs. Kilen/Lesjofors lists these front springs as being correct for the Octavia MK3 2.0TDI 105kW/143PS estate with standard ride height (without listing whether it's for manual or automatic transmission).
Bilstein 37-293215 are sold to replace five different OEM part numbers including 5Q0411105GK and 5Q0411105GL so these front springs will be able to support the weight of the cars that these springs are normally fitted to.
Bilstein 36-292776 rear springs are sold to replace both 5Q0511121AF and 5Q0511121AG, so will be able to support the weight of the car that these are normally fitted to.
Bilstein 36-292936 rear springs are sold to replace 5Q0511121AA, 5Q0511121AB, and 5Q0511121AC rear springs. They are far too soft for your car and won't support the weight of the estate/combi/wagon.
Edited by Carlston
On 26/01/2021 at 01:01, Guest said:
Scout shocks and springs are supposed to be stiffer than standard O3 equipment, I tow with mine and have done for several years, and have not noticed any real sag, although over time the clearance has reduced very slightly. Might be an idea to find a VAG independent to get advice on a replacement for the rear that would be suitable.
Thanx
