Variable Boot Floor
Hello everyone,
I am loving my new Kamiq that I picked up in October.  I am wondering if there is an option to fit the variable boot floor after market and if so where can I buy the parts?
Also possibly looking at fitting the door edge protectors if they can be sourced after market.
Any info links, etc would be fantastic!
Thanks!
Not sure where you are but I seem to remember seeing a review that the Variable floor wasn't available in the UK.  Might have been another car but i am sure it was the Kamiq
I am in the UK.
I know if I was to option the boot floor for a brand new car it is there, and on the website too....
Not easy to retrofit them as far as I'm aware. Someone did it on an Octavia but needed quite a few parts from Skoda.
The variable boot floor is pretty basic in its design and simply sits on a couple or so "rests".  There is no hinging mechanism and no system which causes it to raise or lower; ii's all manual and if you want to use the full boot depth, then you life the variable floor out and stow it somewhere in the garage or house etc.
The "rests" would need fixing - I think they are screwed in - but that's all.   I imagine that the holes are already there for the screws behind the boot lining.
All in all, because of a back problem I need the higher boot floor, but it is rather basic.  I had imagined that it would be variable in such a way that you could raise it and lower, e,g, by some mechanical or hydraulic system rather than having to physically remove it.
I will be in the car later today, so I'll try to remember to take a photo of the "rests" and post them here later today.
Seasider, that would be fantastic. Many thanks!
Here we are.   There appear to be no fixings to the boot floor, so there are just the four fixings all old, two through each of the "rests", one at each side.
Max weight for the floor to take is 75kg if I remember right.
Hope these help.
Variable floor in place
Variable floor raised
Overall view
"Rest", one per side
Attachment method, two per rest
Edited by Seasider
Many thanks.
Very much appreciated.
Not to try and find one....
Glad to help.  I imagine that you may need to have it dealer fitted, that fastener isn't your usual straightforward sort for most people.  It will give yo a day out!
Absolutely!
Many thanks once again.  :)
Hi there,
just wondered how you got on with trying to source the parts for the variable floor? I have spoken to my dealer and they were clueless!
thanks
I have got absolutely nowhere!
Ebay, VAG parts places, dealers.
I think I've hit a dead end... :(
Seasider was on the best track, I have retrofitted 2 vario-floors to an Octavia MK2 and a Yeti and in both cases I used a second hand variofloor from scrapped MK1 Octavia Estates which most had fitted as standard in those days.
The width between the wheel arches is common to both Octavias and the Yeti and I am betting its the same in the Kamiq, you need to adjust the height of the side rails & fix them and if you are OCD like me change the rear profile to match the lofted curve of your vehicle, its all easy DIY woodwork.
For the Yeti you simply use 2 out of the 3 sections, if you search the forum you will find a thread that I started with photos but once you have the second hand floor & side supports in front of you it will be obvious what needs doing.
Great- thank you! At least this points me in the right direction!
I just had it fitted at the time of manufacure.
Along with everyone else. I've just bought a Kamiq. It's six months old. Im wanting to fit the variable boot floor. I've been told these cannot be retro fitted. Also I can't  buy it as a part. So I think the best option is to make one.
I wonder if anyone with the boot floor could be so kind as to give me the measurements please. I'll update this post with photos should I get the measurements. TIA
Dave.....
Dave.....
Yes, I'll measure it tomorrow, weather permitting.  The whole thing is quite basic and I had thought it would be something you could raise and lower, either through hydraulics or by a scissors mechanism.
Thanks seasider. That would be a great help👍
Right, here are some measurements.  I've done them in Imperial as they are easier to read for me than metric.  I hope that doesn't pose any problems.
It would be sensible to check my measurements for yourself before you start measuring out or cutting materials.
The photos I included in the thread earlier on may help you understand the measurements.
The area you are wanting to cover is not square, so some fine tuning of shape will be needed.
Here we go.
Front to back: centre - 27 9/16ths; edge - 26 3/4s.
Side to side: front - 39 5/16ths; back 39 1/8th
There is a hinge 6 1/2 inches from the rear edge of the raised floor to allow you to lift it up for access to the space below.
For the height of your supports at the rear, measure up to the bottom of the lip behind the hatchback catch.
I hope this helps.  Let me know if you need any more info.
Thanks very much that gives me a good idea of what I need wood wise. Thanks again for your time and trouble.
No problem, I'm glad I could help.  Let us know how you get on.
I know that you said you had no luck sourcing the parts, but do you happen to have the required part numbers?
Dave.....
Parts don't appear to be available in the UK.
Just seen your post. I've not been able to have a go at making one yet as I'm ill. So I've followed the link which shows up as a boot floor for a scala. Do they use the same variable floor as the Kamiq?
