Can anyone help decipher B14A612 error - superb 2018?
Can any help decipher these errors on a Superb 2018. Error displayed SOS Emergency call restrictred.Workshop.
============1==============
9457426
Raw code: 904F12
ECU: 75. Emergency Call and Communication Module[Archive (inactive)]
Status: Confirmed
Skoda Rapid EU(A-Entry) 2013 - 2021; Fabia 2015-2021; Scala, Kamiq 2019-2021; Octavia II 2009 - 2013, Yeti 2010 - 2018; Octavia III 2013 - 2020, Kodiaq 2017 - 2021, Karoq 2018 - 2021; Octavia 2020-2021; Superb 2015-2021; Citigo 2012-2021: B14A612: Emergency call speaker
Short circuit to B
Skoda Rapid EU(A-Entry) 2013 - 2021; Fabia II 2011 - 2015, Roomster 2011 - 2015, Rapid 2010 - 2021; Octavia II 2009 - 2013, Yeti 2010 - 2018; Superb II 2008-2015: B104F12: Left audio channel for speech/telephone
Short circuit to B
============2==============
0053
Raw code: 000035
Status: Test failed, Confirmed
Skoda: B10AE38: High pressure sensor
Signal frequency incorrect
Skoda Scala, Kamiq 2019-2021; Octavia III 2013 - 2020, Kodiaq 2017 - 2021, Karoq 2018 - 2021; Octavia 2020-2021; Superb II 2008-2015; Superb 2015-2021: B120A15: Hall sensor in motor 2 for rear hatch
Open circuit/short circuit to B
Skoda: B152613: Lower convert. top compart. cover switch
Open circuit
Skoda: B118F12: Convertible top open position switch
Short circuit to B
Skoda Octavia 2020-2021: P0AC800: Hybrid/EV Battery Temperature Sensor "B" Circuit High
Skoda Octavia 2020-2021: C050A00: Right Front Wheel Speed Sensor Intermittent/Erratic
Skoda: B10C929: Left side vent motor
Implausible signal
Skoda: B11C911: Solen.val. for bleeding lumbar support 1
Short circuit to ground
Skoda Fabia II 2011 - 2015, Roomster 2011 - 2015, Rapid 2010 - 2021; Fabia 2015-2018; Citigo 2012-2021: C10AE12: Electromechanical power steering motor
Short circuit to B
Status bits: 1
Priority: 6
Frequency: 1
Unlearning index: 65
Well that's quite a chunk of text! No idea how many codes that's suppose to be?
Can I suggest you clear everything and see which, if any, come back?
As for your SOS error, this seems a obvious starting point:
  • 2021: B14A612: Emergency call speaker
  • Short circuit to B
There appear to be two issues on the code above. The first one says "Archive Inactive" - and is B14A612: Emergency call speaker  Short circuit to B
This went to the dealer who "updated" the software and cleared. It came back again the next day.  The second time round it seems like the error is  B120A15: Hall sensor in motor 2 for rear hatch
Open circuit/short circuit to B.
The car does not have a powered tailgate? so I am not sure what the errors are.
Both times with a low battery warning. I am getting around 11.4v.
The dealer claims the battery voltage has no connection to the error??
It's very hard to tell from the test you posted, as far as I can tell, there are 7 potential codes:
  • Raw code: 904F12
  • Raw code: 000035
  • Skoda: B10AE38: High pressure sensor
  • Skoda: B152613: Lower convert. top compart. cover switch
  • Skoda: B118F12: Convertible top open position switch
  • Skoda: B10C929: Left side vent motor
  • Skoda: B11C911: Solen.val. for bleeding lumbar support 1
However, most don't seem to be obviously google-able so I'm concerned the scanner isn't being completely helpful with them. For instance, I'm pretty sure you don't have a convertible Superb :D
11.4v is a very low battery voltage so they could be related to a failing battery.
  • Raw code: 904F12
  • Raw code: 000035
Battery seems to be the place to start! It is still under warranty, so I push the dealer again. I suspect the problems will disappear if the battery is sorted.
