Electric window
Hi everyone ,
i have a problem with my skoda fabia mk2 driver window this time , not working , the passenger works fine , changed the switch today nothing happened, the weird thing is when i unlock the car with the key in the keyhole both windows go down and i can close both windows with the switch ( even the driver door that doesn't normally work ) but once up , cant make it go down again with switch , what could it be ??
Thanks in advance
most likely broken wires in the rubber boot between the A pillar and and the door..............common problem.
