Rear Lid not working when pushed
Hi! I'm having trouble opening my rear trunk. It work with opening with the key fob but not with the trunk button.
I have somehow removed the correct code in OBD11, maybe someone could help me with which setting i should change so that the rear Lid opens with a push.
Thanks in advance
I have the same problem on my 2016 Octavia hatchback where upon the boot opens fine when you operate the boot release on the key fob but it won’t open when the doors are unlocked when you use the release button in the rear lid handle.Sometimes it is intermittent. It’s logged fault code B140B29 Release button in rear lid handle implausible signal.
Any ideas what the problem maybe?
Maybe the button/switch itself is faulty
Edited by misor1994
