Dog guard C pillar holes.
Hi, wonder if anyone can help with this. I have a 2018 kodiaq 5 seat, which has at some stage, had the skoda dog guard fitted that required the holes drilled in the c pillar trim, to access the mounting points in the body.
The guard has been removed but there is now a hole each side in the c pillar trim. Does anyone know of any blanking plugs that are suitable for this? I have tried local dealer but they are only saying new trims would be required, and they don’t do any plugs.
Thank you.
Edited by Rowls
Google car trim plugs and I’m sure you’ll find something suitable to fill the holes.
6 hours ago, MSkent said:
I had a similar problem but found these on eBay.  The grey plug is quite a good match for the C pillar, the seller also has black plugs for lower trims.
https://www.ebay.co.uk/itm/30mm-x-25mm-Hole-Plugs-Plastic-Blanking-Masking-Finishing-Inserts-Grey-/222247908622
That’s great, thanks for the link there.
Had a look at some on google but a lot of them were minimum order quantities. The link you gave me looks like just what I need. Thanks again.
