Passenger door central locking
Hi not sure if this is right place but ill go for it because i cant lock passenger door and currently parked against a wall to stop potential theft
2017 se l executive hatch
Noticed yesterday the 10mph auto locking was constantly going off and on while in traffic.
Yesterday my wife couldnt open her door... But i could open from inside
Today i went to work and locked car but passenger door didnt lock
The central locking button on console lit up but made a double-unlock noise when pressed to unlock.  It finally locked but then wouldnt unlock until i unlocked door from inside.
Centre console lock now doesnt even light up and i cant lock passenger door
Checked owner manual and these forums etc... and got my AA employee mate to look but no idea.
Will likely book in to skoda tomorow but incase anyone has had similar with easy fix
Will also post update for future users
Just on the off chance, pull the interior and exterior handles at the same time and see if sorts it. Sometimes does and sometimes doesn’t. Most likely suspect is the locking mechanism.
Could it be the door wiring loom, broken wires?
I had some of those symptoms, but on the driver's door.
10 mph auto lock tried and failed to lock after every move off.
Door wouldn't lock or unlock with the interior or the remote button - I had to use the manual key.
It was after a period of very little use of the car during lockdown and I "cured" it by charging the battery.
Haven't had the problem for over 6 months now.
I could see no reason why that would work, but a friend (former mechanic now TV engineer) offered the suggestion that, although connections into the door may not be broken,
there could be some corrosion within connectors that increases their resistance and requires a better state of charge/higher voltage to "shove" the signal through.
Seemed to make some sense to this unqualified amateur.
Guys. Appreciate your answers. Thank you very much
I will try some of these solutions and hopeully get it sorted today
Thanks again for help
If you have access to any diagnostic scanner (vcds, Carista, vag can pro etc) it would be worth checking for fault codes.
Mine went into the dealers this week for routine service work and I checked with VCDS before as the rear passenger door hadn’t unlocked with the other doors (also the internal lock button was not illuminating when it should) and it listed four fault codes.
The dealer has ordered a new door lock under warranty though luckily it is still working at the moment...
Update. Fixed
Took it to local garage i know and explained problem.
He rang later in afternoon to say theres no faults etc so maybe come down to explain to him again.
Went down and door working perfectly. He said there was no fault codes and all he did was reset the module?. Anyway. All done
1 hour ago, jannerofl said:
Actualizar. Reparado
Lo llevé al garaje local que conozco y le expliqué el problema.
Llamó más tarde en la tarde para decir que no hay fallas, etc., así que tal vez baje para explicarle nuevamente.
Bajó y la puerta funcionaba perfectamente. Dijo que no había códigos de falla y todo lo que hizo fue reiniciar el módulo. De todas formas. Todo listo
have you replaced the bulbs with led?
