Help required.
Hello people
I've changed head unit for an alpine one.
I was thinking about selling my oem head unit removed from my 66 plate yeti. I'm not sure what it's called it is touch screen. I paid my skoda dealer £130 to have smart link enabled for android auto.
Before I go to sell it what's is it worth and does it need unlocking?
I've seen them go for £350+
Help needed
Hi I've installed an aftermarket head unit in my skoda yeti 66 plate.
I no longer need the oem touch screen radio.
Can I sell this unit?
Do I need a radio code?
Also how can identify which one I have?
I paid my local skoda dealer £130 to have this activated. Can this be sold aswell?
Need some help :(
If you want to...
There is no radio code, it'll either need component protection pairing to the new vehicle or hacking to remove CP.
The part number? It's probably a Bolero or Amundsen, given you have a 66 plate, it's likely a MIB STD2 PQ style.
For SmartLink? No, that's tied to your cars VIN and is not transferable.
If you want to...
Thanks for the advice. Can you sell it as it is removed from the car?
What do I need to do to remove any restrictions or pins?
I would sell it as is.
I'd make it clear that:
- it's been removed from your car and not stolen
- it will need component protection pairing or removing
- coding is the responsibility of the buyer
You can have CP removed and all functions unlocked but I'm not sure how much it costs these days or if it can be done remotely. @pab567 is the resident guru but he'll probably need the part number to confirm.
Yes :) part number tells everything
Hi mate the part is skoda 5L0035200B
Probably going to stick it on ebay
It's Bolero MIB STD2 PQ. Can be installed directly only in Yeti FL (requires Components Protection removal). After rework, can be installed in PQ cars like Fabia II FL, Super b II, Octavia II FL, Rapid.
Edited by pab567
I don't spose you know the value of these so I can price accordingly.
Is it a good unit to have? To keep hold of?
Should I sell it with the smartlink I got from the dealer?
Much appreciated
When you Google the part number it comes up with Amundsen?
I've attached a pic
Advantage: it supports SmarLink (MirrorLink, Android Auto and Apple CarPlay)
Disadvantage: it does not support DAB/DAB+
Unfortunately SmartLink does not matter so much here as in case of Yeti FL it will be deactivated when CP is removed and in case of other cars unit must be hacked anyway...
It is Bolero. Amudsen part numbers are 5L0035680x where x is a letter.
Thank you appreciate your help.
What would you say it's worth?
IMHo 200-250 GBP
how can this be fitted in FL mk2 Octavia ?
You need to have the unit patched to disable component protection and enable all features.
You then need a 40pin to 52pin quadlock adaptor and an appropriate USB socket (plus wire) if you want to use smartlink. The AM/FM connections are the same. When I fitted one, I had to trim the rear of the cage slightly so it didn't foul the USB fakra.
It might need a new gateway but I'm not sure. It uses the same facia as the Amundsen and Columbus :)
3 hours ago, pab567 said:
IMHo 200-250 GBP
You have been a great help
