logo recommendation please?
hi guys,
my logo on the center of my wheels are all pretty much messed up, was wondering if you guys would get the same ones or get an upgraded ones?
this is what i have got now.
https://i.postimg.cc/159PJb60/IMG-3604.jpg
many thanks guys :)
I just painted mine black to match the wheels😄
If that is yours, it looks like you have removed the actual logo section, from the actual carrier. The carrier, or wheel centre cap, usually has the logo permanently attached and you just pop the whole thing out, either by taking off the wheel and pushing from the inner side of the wheel or if you can manage, stick something on to the centre cap with hot glue, pull it off and then break the glue seal. (Don't add too much or it'll not come off easy).
That will be ok if you are throwing them away. I fitted the newer style logo centre caps to my 2009 Greenline. It looks nicer but I used non-genuine parts for around a fiver and prior to fitting them, took the precaution of giving them a coat of clear lacquer as I already had some so it cost nothing extra. Genuine ons are around that price, per cap!
yeah i did get some more but it came with double sided sticker but not happy with it.
have you got a link for your please?
i want some proper/original ones but if there is better/upgraded ones then il have them instead.
I got stick on ones from wish last year. They looked the part but the 2 back ones have fallen off over time. I checked ebay and honestly it was as cheap to get Oem looking pop in ones brand new.
you got the link for the oem please?
They aren't OEM per se. They're just a proper clip in job rather than a sticker that goes over the top. I havent bought these, these are just ones I found in eBay.
https://www.ebay.co.uk/itm/373434903033
I've been meaning to get some myself but I keep forgetting.
i prefer the clip on ones but last clip on ones i bought didnt fit though.
Amazon have have a selection of Skoda caps . just remember and measure your old ones to get the right size 📏
Should be 56mm for a fabia.
As mentioned, 56mm should be the correct ones. I think mine were either eBay or aliexpress and cost around a fiver the set. The black and silver version, not the older, green ones. I still have them in a box of spares I kept.
