Please help! Interior map light housing disassembly
Hi everyone,
I'm replacing my interior lights with LEDS and have successfully removed the front map light cover and replaced one bulb! Hurrah.
The second bulb came out but when I tried to insert the new one into the socket, the actual socket the bulb clips into has become unstuck from the housing and disappeared above the black casing. How can I remove the black plastic to get at the loose socket to reattached it?
TIA!
This may help
Thank you! I’d just watched something similar and done what you see in your video. Fixed it right up. Thank you!
Now to have a go at replacing the puddle lights with super bright ones. Can’t help but think “if it ain’t broke...”
