HELP! Rear brake pads
Hi everyone does anyone what size pads I need for a mark 2 fl octavia.
There's two different options on euro
One set of pads fit 272mm
One set of pads fit 280mm
Any ideas guys.
The easiest, and foolproof, way is to remove a rear wheel and measure the disc. This will also give you the opportunity to inspect the disc, especially the inboard side, to determine whether you need new discs as well.
If it's for a VRS I would say the larger 280mm disc ones are correct.
Check the option codes sticker in the boot to confirm.
A quicker way to measure disc without removing the wheel is to make a Large “ C” shape out of say cardboard and then position it in between the alloy wheel and measure the disc width. Works well !
I think the disks on my VRS were 272 if I remember correctly. Was a while back though.
You could always order both and return the incorrect ones.
I had a look in the service I found 1KT so looks like its 272mm
Book*
They might be a bit worn down.
Phone dealer and get sizes.
On 25/04/2021 at 10:25, Benskoda170cr said:
I had a look in the service book I found 1KT so looks like its 272mm
There's four different sizes listed in the Skoda online parts catalogue:
253mm (Build Code 1KD)
Brake pads 1K0698451J
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2012/drive_standart/663/hg_ug/615/subcategory/615060/part_id/2550123/lang/e
258mm/260mm (Build Code 1KF)
Brake Pads 1K0698451G
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2012/drive_standart/663/hg_ug/615/subcategory/615065/part_id/2550123/lang/e
272mm (Build Codes 1KS, 1KT)
Brake Pads 5K0698451
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2012/drive_standart/663/hg_ug/615/subcategory/615063/part_id/2550123/lang/e
282mm (Build Code 1KP)
http://www.oemepc.com/skoda/part_single/catalog/sk/markt/CZ/modell/OCT/year/2012/drive_standart/663/hg_ug/615/subcategory/615062/part_id/2550123/lang/e
Edited by Carlston
