Stuck in gear
Hi folks, daughters 2008 Fabia 1.4 diesel has a major problem. Seemed to have clutch problems and was recovered to home. On arrival recovery driver attempted to pop the car on the drive. Ended up stuck in 1st with no movement when raising the clutch. Now stuck on the drive and can't go forward or back. Any ideas on how to disengage so we can get it off the drive please?
I seriously doubt that both the clutch AND the gearbox have broken at the same time.
It should be possible to get the gearbox into neutral if you can unload the transmission by jacking one of the front wheels off the ground.
