VCDS - HELP - Databus, el. seat
Hello everyone,
Could you help me with that pls? I check these problem and I dont know where is the problem. Have you some tips where I have find?
Saturday,23,January,2021,16:11:34:08197
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20201125 DS322.1
www.Ross-Tech.com
VIN: TMBLE7NP9G7019516   License Plate:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 42 44 47 52
          55 5F 6C 6D A5 BB BC
VIN: TMBLE7NP9G7019516   Mileage: 150649km-93608miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 0C1D00322466010B3000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001002
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B02F64B53873003F60-807F
3 Faults Found:
14867 - Bank 1: CMP Sensor 3 (G300) / Engine Speed Sens (G28)
          P0017 00 [096] - Incorrect Correlation
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 150541 km
                    Date: 2021.01.22
                    Time: 05:35:09
                    Engine RPM: 741.75 /min
                    Normed load value: 23.9 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 13 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 14.863 V
                    Unlearning counter according OBD: 39
                    Engine: operating status: IS
                    STATE_VCP: enable
                    Engine oil temperature: 57.0 °C
                    CAM_VCP[EX_1]: 22.945 °
                    CAM_SP_IND_VCP[EX_1]: 0.000 °
                    PWM_HLD_VCP[EX_1]: 8.984 %
                    STATE_PWM_VCP[EX_1]: HLD
14870 - Bank 1: Camshaft A (Intake)
          P0011 00 [096] - Retard Setpoint not Reached (Over-Advanced)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 150569 km
                    Date: 2021.01.22
                    Time: 14:58:46
                    Engine RPM: 772.50 /min
                    Normed load value: 16.1 %
                    Vehicle speed: 27 km/h
                    Coolant temperature: 106 °C
                    Intake air temperature: 39 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 12.890 V
                    CAM_VCP[IN_1]: 25.586 °
                    CAM_SP_IND_VCP[IN_1]: 15.000 °
                    MAP_MES_SAE: 28 kPa
                    Engine oil temperature: 102.0 °C
                    PWM_HLD_VCP[IN_1]: 57.172 %
                    STATE_PWM_VCP[IN_1]: pas
14869 - Bank 1: Camshaft B (Exhaust)
          P0014 00 [096] - Retard Setpoint not Reached (Over-Advanced)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 150496 km
                    Date: 2021.01.21
                    Time: 06:25:27
                    Engine RPM: 1523.50 /min
                    Normed load value: 9.8 %
                    Vehicle speed: 30 km/h
                    Coolant temperature: 91 °C
                    Intake air temperature: 11 °C
                    Ambient air pressure: 960 mbar
                    Voltage terminal 30: 14.785 V
                    Unlearning counter according OBD: 37
                    Engine: operating status: PL
                    CAM_VCP[EX_1]: 18.305 °
                    MAP_MES_SAE: 23 kPa
                    Engine oil temperature: 60.0 °C
Readiness: 0000 0000
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4908
   Revision: 06253104    Serial number: TFK01508132605
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 53F28EAB2B7748C39E0-8007
No fault code found.
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Component: ESC           H42 0723
   Revision: 00000000    Serial number: 62405000000832
   Coding: 1E076B9C54212B75077C070141C96978D62AD4E0E08296F5384150F8C209
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034.rod
   VCID: 7AAC030FEC5D598B3D6-802F
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0709
   Revision: 00036000    Serial number: 0377207988
   Coding: 030C0C0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3A2CC30FACDD998B7D6-806F
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65027771
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 AT    HW: 3V0 907 044 AT
   Component: AC Automat    H32 3601
   Revision: 20K04000    Serial number: 00000B00018312
   Coding: 1201000400040001100500410010100A
   ASAM Dataset: EV_ACClimaPrehVW37X 002009
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 065467FFA8A52D6B49E-8053
1 Fault Found:
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 44
                    Reset counter: 179
                    Mileage: 149982 km
                    Date: 2021.01.05
                    Time: 14:55:01
                    Outside temperature: 2.5 °C
                    Voltage terminal 30: 11.9 V
                    System run time-Engine running time: 0 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: Malfunction
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061523700480
   Coding: 0C011B76C2C722FB17844096B11C572C0800000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094E6CC3B9BB421324C-805D
   Wiper motor control module:
   Subsystem 1 - Part No SW: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x LL 150801  032 0121
   Serial number: 00000001507300302241
   Coding: 165DDD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y15M09D08H01M51S08
   Coding: 0088DF
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  006 0326
   Serial number: 000000000ZY151950JU3
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000033151593
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615237
   Coding: 0271161851
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D4658D3CDD35E33084-8059
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0192
   Coding: 320067C351FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3430ED378EB96FFBA7A-8061
2 Faults Found:
0836 - Databus
          U1123 00 [008] - Received Error Message
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 167
                    Reset counter: 174
                    Mileage: 150486 km
                    Date: 2021.01.20
                    Time: 15:46:10
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.6 V
                    Velocity_vehicle_reference: 6.67 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.00 m/s²
                    Status_ACC_System: ACC_StandBy
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 178
                    Mileage: 150496 km
                    Date: 2021.01.21
                    Time: 06:25:27
                    Control Module temperature: 12 °C
                    Voltage terminal 15: 14.7 V
                    Velocity_vehicle_reference: 8.30 m/s
                    Longitudinal_acceleration_vehicle_reference: -0.33 m/s²
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H16 0120
   Serial number: 18081541350298
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 372ADA3B9FCF84E3828-8063
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R11GGDM
   Coding: 98CCC0C0000000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 480 002 108 15
   Component: SideSensor_Df  001 0887
   Serial number: 3570000000087078161A
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 480 002 108 15
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000F8811261F
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 480 401 708 15
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002A71CB0C03330U
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 808 15
   Component: SideSensor_Pr  001 6149
   Serial number: 3520002AB1CB0C04B2CC
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 808 15
   Component: FrontSensor_D  001 6149
   Serial number: 3550002991CF2D8602FL
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 BD    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20150901500564
   Coding: 6410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73B22E2BCB3728C37E0-8027
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 3V0 920 710     HW: 3V0 920 710
   Component: KOMBI         305 6421
   Coding: 07A5081AFF840008018B7B021001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
   VCID: 6C8035579609F73BBFA-8039
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2227
   Revision: --------    Serial number: 28081510801362
   Coding: 0B0100046F085900EB00025A9C0F00010001070000000000000000000000
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013.rod
   VCID: 75B61033C54336F3504-8021
   Generator:
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000C1910210815
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 8242307603
   Inverter for electrical outlet:
   Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
   Component: WECHSELRICHTE  H53 0033
   Serial number: 0146543
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7082
   Serial number: HA1-00012.06.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 002013
   ROD: EV_AllWheelContrHA1VW37X.rod
   VCID: 46D4A7FFE825ED6B09E-8013
Address 2B: Steer. Col. Lock (J764)       Labels:* 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0031
   Serial number: 15000045024003
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BE2423B12B1AD38CC-8025
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OH517177
   Coding: 001000000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B22C60BA3E7A083660-806F
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 190815BHI00361
   Coding: 001D0820DE00040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 43D2BEEBDB17D8432E0-8017
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-143.clb
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2033
   Revision: 00000000    Serial number: 0000338595
   Coding: 01010011005001
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0110
   Revision: 00000001    Serial number: SKZ8Z1FAS00GSR-
   Coding: 0384020000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 2D06F8536D933E33E84-8079
1 Fault Found:
1559 - Cooling Fan for Housing
          B126B 01 [008] - Electrical Failure
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 179
                    Mileage: 150040 km
                    Date: 2021.01.11
                    Time: 15:22:50
                    Voltage terminal 30: 14.8 V
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 210815BHK17931
   Coding: 001D0220DE00040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 42DCBBEFC40DD14B256-8017
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 06E202003F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40D8B1E7CA01C35B332-8015
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0005
   Coding: B20000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0005
   Coding: B20000
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 021 A    HW: 3V0 035 021
   Component: MU-H-LND-EU   H42 0318
   Serial number: A433H0F7508119
   Coding: 03840201000000001111120200880A102F0003E4012081009E
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 2516007335630673204-8071
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H44 1028
   Serial number: SKZ8Z9RAM007D7
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 801 JJ    HW: -----------
   Component: ECE 2015/2016  --- 0122
   Serial number: --------------------
   Compact disc data bank:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1011
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 04840201A600201F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005.rod
   VCID: 77AA1A3BDF4F44E3428-8023
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 G    HW: 5Q0 959 107 G
   Component: HDSG-Modul    H12 0250
   Revision: --------    Serial number: 30212461700000
   Coding: 0D08
   ASAM Dataset: EV_DeckLidCONTIAU736 001011
   ROD: EV_DeckLidCONTIAU736_AU73.rod
   VCID: 3C20C517A6E9A7BB6FA-8069
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 26081511K10778
   Coding: 020408020000040100262344C040A00090000E100020
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_001_VW36.rod
   VCID: 3828D90792D18B9B8B2-806D
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0041
   Serial number: 140815BH10076B
   Coding: 001C00208000040000001100
   ASAM Dataset: EV_DCURearDriveMINKLO 006003
   ROD: EV_DCURearDriveMAXCONT.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 140815BHD12055
   ASAM Dataset: EV_DCURearPasseMINKLO 006003
   ROD: EV_DCURearPasseMAXCONT.rod
End----------(Elapsed Time: 02:02, VBatt start/end: 12.1V/12.1V)-----------
The 2nd question is, If I enabled easy entry, autoscan wrote fail with el. seat. Have you some tips, how to fix that problem (turn off easy entry is not right way :D)
Friday,02,April,2021,12:44:46:08197
www.Ross-Tech.com
VIN: TMBLE7NP9G7019516   Mileage: 152061km-94486miles
03-ABS Brakes -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
   Revision: --H13---
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Mileage: 151048 km
                    Date: 2021.02.13
                    Time: 09:03:15
                    Engine RPM: 1706.75 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 74 km/h
                    Coolant temperature: 87 °C
                    Intake air temperature: 6 °C
                    Voltage terminal 30: 14.882 V
                    Unlearning counter according OBD: 13
                    Engine: operating status: PUC
                    STATE_VCP: enable
                    Engine oil temperature: 42.0 °C
                    CAM_VCP[EX_1]: 23.320 °
                    PWM_HLD_VCP[EX_1]: 8.826 %
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 151024 km
                    Date: 2021.02.05
                    Time: 18:48:29
                    Engine RPM: 1453.00 /min
                    Normed load value: 39.2 %
                    Vehicle speed: 38 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 9 °C
                    Ambient air pressure: 970 mbar
                    Unlearning counter according OBD: 10
                    CAM_VCP[EX_1]: 33.398 °
                    CAM_SP_IND_VCP[EX_1]: 14.000 °
                    MAP_MES_SAE: 87 kPa
                    Engine oil temperature: 37.0 °C
                    PWM_HLD_VCP[EX_1]: 24.908 %
                    STATE_PWM_VCP[EX_1]: pas
   Coding: 0014
1 Fault Found:
16401 - Tire Pressure Warning
          C102D 00 [008] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 152000 km
                    Date: 2021.03.29
                    Time: 08:19:37
   Coding: 130C0C0703
1 Fault Found:
          B10AF 04 [009] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 91
                    Reset counter: 210
                    Mileage: 150942 km
                    Date: 2021.02.05
                    Time: 09:23:34
                    Outside temperature: 15.0 °C
                    Voltage terminal 30: 14.1 V
   Coding: 165DDD
   Coding: 0688DF
   Alarm horn:
   Coding: 0271161851
1 Fault Found:
2068 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 219
                    Mileage: 151024 km
                    Date: 2021.02.05
                    Time: 18:48:29
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 13.2 V
                    Velocity_vehicle_reference: 12.72 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.30 m/s²
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 6410
   Generator:
   Coding: 0301
   Coding: 001000020000010001A080808080000000008181000000D4
1 Fault Found:
65593 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 11
                    Reset counter: 246
                    Mileage: 151035 km
                    Date: 2021.02.09
                    Time: 19:38:59
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 7
                    Reset counter: 238
                    Mileage: 151039 km
                    Date: 2021.02.09
                    Time: 19:46:05
                    Voltage terminal 30: 14.6 V
   Coding: B20000
   Coding: B20000
   Data carrier:
   Coding: 0D08
End----(Elapsed Time: 02:00, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
Thank you
