Fault code p0562.
  • Sponsor
Gimme ten minutes. :)
  • Replies 55
  • Views 29.5k
  • Sponsor
Accelerator pedal connections as follows:
Pin 1 at pedal grey/black to ECU pin 13
2 at pedal yellow/green to ECU 15
3 grey/red to 74
4 white/blue to 53
5 grey/blue to 8
6 brown/blue to 54
Pins 2, 3, 4 are labelled 5V, - and s (signal, presumably) respectively for sensor 1 on the pedal.
1, 5, and 6 are labelled 5V, - and s respectively for sensor 2.  I guess this one would be the "throttle sensor/switch B" that your fault code references.
Thanks wino, ill get on to it now..:thumbup:
  • 4 years later...
On 18/05/2021 at 12:02, Breezy_Pete said:
That same fuse 13 still applies, as does the relay in position 1 of the under-bonnet fuse/relay box.  Fuse 10 in there, a 5 amp one, may also be worth checking.
can you attatch where i can find all the ground connections to check??
  • Sponsor
You can download all the circuits for any Skoda model at erWin Skoda.
i am a bit rusty.. is there eny way you can point me in a direction? i have a video attached of the problem i think.. P0562
