Skoda superb ll wrong coding please help thank you
Skoda superb ll 2010 with clja engine 2.0 TDI 103 KW
So i need full scan of vcds for correct the all control modules coding please help me
What are you trying to do?
The modules and coding will depend on the spec level and which options were fitted so just looking for a scan might not help you.
Can you post an autoscan from your vehicle as that'll help find other similar cars.
What DID you do?
Did you recode anything without a back up scan in the first place?
As langers2k said, post a complete scan.
42 minutes ago, 26DIPP said:
What DID you do?
My guess would be a cheap VCDS clone scrambled or erased coding on one or more control modules. It's been known to happen in the past.
Yes its clone vcds from china
Ok
23 hours ago, 26DIPP said:
What DID you do?
Wednesday,19,May,2021,21:37:35:00233
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 20.12.0.0
Data version: 20201124 DS322.0
www.Ross-Tech.com
Dealer/Shop Name: TOOR
VIN: TMBBEK3T0AA303190   License Plate:
Mileage: 92630km-57557mi   Repair Order:
Chassis Type: 3T-SK46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 55 56 62 72
          77
VIN: TMBBEK3T0AA303190   Mileage: 92630km-57557miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Not registered 0001
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CLJA)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 JD    HW: 03L 906 018 BR
   Component: R4 2.0l TDI   H22 9977
   Revision: 42H22---    Serial number:
   Coding: 001D0012042500080000
   Shop #: WSC 10100 663 12345
   ASAM Dataset: EV_ECM20TDI01103L906018JD 003005
   ROD: EV_ECM20TDI01103L906018JD.rod
   VCID: 75E154D3D4C1DF2C20-8020
1 Fault Found:
4714 - Steering Column Control Module
          U0212 00 [039] - No Communications
          Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 92639 km
                    Date: 2021.05.19
                    Time: 08:36:52
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 57 °C
                    Intake air temperature: 35 °C
                    Ambient air pressure: 970 mbar
                    Voltage terminal 30: 12.160 V
                    Unlearning counter according OBD: 40
                    Limitation: accelerator pedal: 126.6 Nm
                    CAN status - engine control module-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 44
                    CAN status - transmission control module-Bits 0-7: 0
                    CAN status - brake control module 1-Bits 0-7: 0
                    CAN status - brake control module 2-Bits 0-7: 0
                    selected gear-Bits 0-7: 0
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2204
   Revision: 05151112    Serial number: 00001008230825
   Coding: 0000020
   Shop #: WSC 52104 002 1048576
   VCID: 183F7D672B934244DB-804C
No fault code found.
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
   Component: ESP MK60EC1   H30 0105
   Revision: 00H30001
   Coding: 863D6016092200FD610C06ED90190081350000
   VCID: 04073917871BF6A427-8050
4 Faults Found:
03306 - Coding Not Valid
            000 - - - Intermittent
             Freeze Frame:
                    Fault Status: 00100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 02:37:51
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 4161
                    Count: 40704
                    Count: 65280
                    Count: 64768
                    Count: 0
01486 - System Function Test Activated
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 21:46:42
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 320
                    Count: 43520
                    Count: 0
                    Count: 65023
                    Count: 0
01309 - Power Steering Control Module (J500)
            008 - Implausible Signal
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 21:46:42
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 8212
                    Count: 43520
                    Count: 0
                    Count: 65023
                    Count: 0
01487 - System Function Test
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 23:10:22
             Freeze Frame:
                    Count: 0
                    Count: 14
                    Count: 12800
                    Count: 321
                    Count: 47360
                    Count: 0
                    Count: 65279
                    Count: 0
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 AR    HW: 3T0 907 044 AR
   Component: Climatronic   H15 0401
   Revision: 00005001
   Coding: 0000001002
   Shop #: WSC 33361 790 00999
   ASAM Dataset: EV_Climatronic A01006
   ROD: EV_ClimaAutoBasis_SK46.rod
   VCID: 020B3F0F950FF89415-8056
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 P    HW: 1K0 937 087 P
   Component: BCM PQ35  H+  104 0615
   Revision: 00104 AE
   Coding: 48990ABBE85BF1C040080080110089E4407000AE732089605C0040000040
   VCID: 3E738BFFA9775C7431-806A
   Subsystem 1 - Part No: 3T2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 20081  26  0602
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 040910 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 1K8 951 171
   Component: DWA-Sensor 00  001 0104
4 Faults Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation
             Freeze Frame:
                    Fault Status: 01100101
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
             Freeze Frame:
                    Fault Status: 01101001
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
02743 - Bulb for Brake/Turn Signal Light; Right
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:45:20
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475 C    HW: 1Z0 919 475 A
   Component: PARKHILFE 8K  H06 0006
   Revision: --------    Serial number: 66531022102700
   Coding: 100104
   Shop #: WSC 33361 790 00075
   VCID: 4189F003D889238C4C-8014
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                    Temperature: 23.0°C
Address 15: Airbags        Labels: 5N0-959-655.lbl
   Part No SW: 3T0 959 655 C    HW: 3T0 959 655 C
   Component: J234__LAQ VW10 HI   1918
   Revision: 20014000    Serial number: 003K2PJMJ4QB
   Coding: 0016721
   VCID: 4189F0031889238C4C-8014
   Subsystem 1 - Serial number: 6332MTS680842320
   Subsystem 2 - Serial number: 6342MTS683972320
   Subsystem 3 - Serial number: 6351HTS6KUKCD6KJ
   Subsystem 4 - Serial number: 6361HTS6P32ED6KR
   Subsystem 5 - Serial number: 63727TS6DNAID6KR
   Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Component: LENKS.MODUL   009 0136
   Revision: FF010038    Serial number: 20100830100284
   Coding: 0812140000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76E353DFC9C7D43429-8022
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 830000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 3T2 920 841 H    HW: 3T2 920 841 H
   Component: KOMBI         H04 0406
   Coding: 110E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
   VCID: 397998E3B8597B4C04-806C
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530     HW: 1K0 907 951
   Component: J533  Gateway   H27 5603
   Revision:   H27       Serial number: 240810F2000319
   Coding: EDA1FB0600060200001303
   VCID: 6DD17CB3749117ECD8-8038
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:54
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0406
   Coding: 000002
   Shop #: WSC 00001 001 00001
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: 6ADB77AF8D7F00D4BD-803E
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C8 959 760     HW: 3C8 959 760
   Component: J810                0801
   Revision: 00002000    Serial number: 00000000000000
   Coding: 0000003
   Shop #: WSC 34447 004 1048576
   VCID: 72EB6FCF6DAFC81405-8026
Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
   Part No SW: 8X0 959 793 C    HW: 8X0 959 793 C
   Component: TSG FA        H09 0409
   Revision: --------    Serial number: --------------
   Coding: 011D0220DE01001000
   VCID: 4D91DC3314D1F7ECB8-8018
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 233    3001
   Revision: 00H17000
   VCID: 3169A0C3A829B30CBC-8064
1 Fault Found:
03075 - Parallel Parking Assistance Control Module (J791)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                    Voltage: 12.13 V
                        DD
                    Temperature: 33.0°C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
   Part No SW: 8X0 959 792 C    HW: 8X0 959 792 C
   Component: TSG BF        H09 0409
   VCID: 4C97D137EFCBFEE4AF-8018
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0142
   Revision: 00H04000    Serial number:
   Coding: 1377095
   VCID: 3467A9D7573B8624D7-8060
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
6 Faults Found:
02233 - Left Headlight Power Output Stage (J667)
            004 - No Signal/Communication - MIL ON
             Freeze Frame:
                    Fault Status: 11100100
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:53
             Freeze Frame:
                    Voltage: 12.07 V
                    Speed: 0.0 km/h
                        ABS 1
02234 - Right Headlight Power Output Stage (J668)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:53
             Freeze Frame:
                    Voltage: 12.07 V
                    Speed: 0.0 km/h
                        ABS 1
01042 - Control Module; Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Status: 11100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
            005 - No or Incorrect Basic Setting / Adaptation - MIL ON
             Freeze Frame:
                    Fault Status: 11100101
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 3T0 035 156 C    HW: 3T0 035 156 C
   Component: BOLERO        014 0029
   Revision: -----28S    Serial number: SKZ4Z3K1117551
   Coding: 0D0004000004
   VCID: 2E53BBBF7917ACF4A1-807A
Address 62: Door, Rear Left (J388)       Labels:. 8X0-959-795.clb
   Part No SW: 8X0 959 795 B    HW: 8X0 959 795 B
   Component: TSG HL        H06 0409
   Coding: 010C00200001001000
   VCID: 4E93DB3F19D7CCF4C1-801A
Address 72: Door, Rear Right (J389)       Labels:. 8X0-959-795.clb
   Component: TSG HR        H06 0409
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668431278
   Coding: 0200000000010110
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 326BAFCF652F8814C5-8066
End---------------------(Elapsed Time: 03:05, udsna)-----------------------
www.Ross-Tech.com
          77
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 92639 km
                    Date: 2021.05.19
                    Time: 08:36:52
   Coding: 0000020
   Revision: 00H30001
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 02:37:51
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 4161
                    Count: 40704
                    Count: 65280
                    Count: 64768
                    Count: 0
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 21:46:42
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 320
                    Count: 43520
                    Count: 0
                    Count: 65023
                    Count: 0
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 21:46:42
             Freeze Frame:
                    Count: 3
                    Count: 14
                    Count: 4096
                    Count: 8212
                    Count: 43520
                    Count: 0
                    Count: 65023
                    Count: 0
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 24
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.09
                    Time: 23:10:22
             Freeze Frame:
                    Count: 0
                    Count: 14
                    Count: 12800
                    Count: 321
                    Count: 47360
                    Count: 0
                    Count: 65279
                    Count: 0
   Revision: 00005001
   Coding: 0000001002
   Revision: 00104 AE
   Coding: 00D7B7
   Coding: 0730ED
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.20 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        OFF
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:45:20
             Freeze Frame:
                        Term 15 On
                    Voltage: 11.80 V
                        ON
                        ON
                        Term 50 Off
                        OFF
                        ON
   Coding: 100104
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                    Temperature: 23.0°C
   Coding: 0016721
   Coding: 0812140000
   Coding: 830000
   Coding: 110E01
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:54
   Coding: 000002
   Coding: 0000003
   Revision: 00H17000
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:52
             Freeze Frame:
                    Voltage: 12.13 V
                        DD
                    Temperature: 33.0°C
                    RPM: 0 /min
                    Speed: 0.0 km/h
                    Speed: 0.0 km/h
                    Count: 0
   Coding: 1377095
   Coding: 00000255
   Coding: 00000255
6 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:53
             Freeze Frame:
                    Voltage: 12.07 V
                    Speed: 0.0 km/h
                        ABS 1
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 25
                    Mileage: 92639 km
                    Time Indication: 0
                    Date: 2015.10.10
                    Time: 08:36:53
             Freeze Frame:
                    Voltage: 12.07 V
                    Speed: 0.0 km/h
                        ABS 1
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
            000 - - - MIL ON
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 25
                    Time Indication: 0
             Freeze Frame:
                        Invalid
                        Invalid
                        Invalid
   ROD: UHVNA.rod
So what were you doing/trying to do when this problem happened?  And why not spend the extra money on a genuine VCDS cable? It's really not that expensive, and works much more reliably that the Chinese clones.
Please give the solution
You haven't given enough information to allow us to solve this problem. The messed up coding is the result of something happening to the car, and that is the problem that needs to be solved. As @langers2k pointed out earlier in the thread, we don't know what the coding necessarily should be for your specific car. If you want help, explain what was done to the car to cause this problem first, along with any troubleshooting steps you have done or solutions you have attempted.
As above, given you've not said what you did or were trying to do before this happened and you're using a clone which may have cause some of these issues, I'm not sure I can help.
I'd suggest you contact whoever you purchased 'VCDS' from for support or find someone with genuine tools to take a look.
On a genuine VCDS you get a Log of all the changes made, the china copy might have that still coded. So even if this is a cheap china copy look for the log and retrace your steps. Then return or bin your copy and get a genuine VCDS.
Next time get an autoscan saved before you change anything.
