Warning light - any ideas
Hi, I have a 2003 Octavia 1.9tdi. The warning light ( looks like a coil) has appeared on the speedo. Does anyone have any ideas what it can be. Also the Vag-com tool, where is the best place to buy it. Cheers Gordon
It sounds like the glow plug light,
But then again I know nothing...:o
Sorry, you said speedo??
Hi Mate
Easiest thing to check is the brake light switch.
Just check to see if the brake lights are working.
If not you need a new switch.
If they do then you may need to have a diagnostic check done on your car
Sarah
If you want a suitable cable , I have one you can have for £17 delivered.
That will run with the free version of VAG-COM to read fault codes or you can buy the full version if you want to play with settings
Id be interested in that cable Dr Zoidberg. Can you point me towards the software too.
The version you will need for other than a Ross-Tech branded interface can be downloaded from here. Alex can probably advise which version is most suitable.
Thanks to all who replied, as posted, I found that both brake lights had failed. Gordo
