Thermostat & Thermo-switch
With switch 75IMG_20210910_111700.thumb.jpg.ec56f19ee9364a146c053b5e1d7b5e4b.jpg
  • Replies 83
  • Views 7.8k
  • D.FYLAKTOS
    D.FYLAKTOS
    Who said that? Here in Greece we have hot cliamate too and the Skoda mechanics which had Felicia some years ego suggest 80-85C and even 75-80C thermo-switch I have use all the scales from 70
  • @Agalalh You mentioned you don't want the radiator fun to run almost all the time. A lower temperature thermo-switch will keep the fan working often. It is not economical to use the rad
  • D.FYLAKTOS
    D.FYLAKTOS
    The temperature radiator fan switches have scales at 5 °C Which thermo switch says on that is for 88C only? Take a look some Mahle:   https://www.euspares.co.uk/manufacturer/mahle-
16 hours ago, Agalalh said:
So
Where is Wright answer to my question tell now nobody tell witch is better
It depends on the country (weather conditions).  Here in Athens we have warm weather and traffic so for our car a thermostat 87'C and 80-85'C fan switch is fine. In Egypt the weather is similar to ours so why you go to the extreme with 80'C thermostat and 70-75'C fan switch?
Thank you for your reply
 Egypt weather hot more than Athens and the best thermostat for hot Counties is 80 c i tried switch 82 its good but run along more than 75
With switch 75
Your fan now does not working overtime especially in traffic?
Yes this is where my felly ran with 70-75 switch, but belive me friend you are going to regret it, this duty cycle simply cannot be sustained by the fan.
You need to let it rest.
That is why I asked which one is better
Summer in Greece means moisture and even 45'C outside so we use mainly 80-85 fan switch.
With 70-75'C switch your fan will work very early and continue to work like mad,you will pay this in fuel consumption and early motor fan failure.
pls send me this code for switch fan 80-85
BEHR or MAHLE
Temperature Switch radiator fan
Item number:TSW 6
Switch-on point [°C]:85
Shut-off Point [°C]:80
EAN:425019291885
