Can someone help me with missing VCDS ROD files?
First of all i have to admit i have a fake VCDS cable. But it was working fine before with my skoda laura and yeti. suddenly am getting missing rod files errors. before when i get this error, i usually download other versions of VCDS and copy the files from there. but these new files are not available anywhere. somehow they replaced the name i think.
If some one using VCDS and wanted to help me, please check below path for the missing ROD file and can share it.
"C:\Ross-Tech\VCDS\UDS_EV"
Missing ROD fileS name are below
EV_Komb_iUDS_VDD_RM09 A04089 (VW36*)
EV_ECM20TDI0110L3906018EK 003010 ()SK35
Thanks in advance
Manish Sharma
Up to date software and related stuff is reserved for genuine customers of Ross Tech. If you bought your software and cable from elsewhere you should ask the person who took your money for technical support.
Agreed - don't expect much sympthy from any Briskoda member for dodgy/pirated VCDS leads.  You might like to consider a copy of ODBEleven instead which is cheaper and less likely to break your car.
